1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Multiple target os-class application build
To: "Andrew Johnson" <[email protected]>, "Sue Witherspoon" <[email protected]>
Cc: [email protected]
Date: Wed, 27 Feb 2008 13:18:41 -0600
I'd really like to see this changed in a future release, so that DBD
files are put in an architecture-specific directory, and have them
accept statements that allow lines to be included/excluded for specific
architectures.
The scheme one has to use now is a real pain, particularly when building
complex applications that use multiple modules.  If module A has
architecture-specific DBD files, then module B that depends on it needs
to know that.  B needs to be modified if A is modified to add a new
architecture, etc.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Andrew Johnson
> Sent: Monday, February 25, 2008 2:56 PM
> To: Sue Witherspoon
> Subject: Re: Multiple target os-class application build
> Hi Sue,
> >     I sent this question thru tech-talk while tech-talk
> 'seemed to be
> > down'. The question did come up two days later but I got no
> response
> > at
> > all.
> We had a mailman outage last week which delayed a whole lot
> of messages after a python upgrade on our webserver; I hope
> it's all fixed now.
> >    I have an application that will run on a vxWorks ioc and
> an RTEMS
> > ioc.  Obviously, there are some functions that are peculiar to
> > vxWorks.
> > The Makefile Definitions allow for this by using
> <app>_SRCS_<osclass>
> > or vxWorksOnly_SRCS etc.  But is there a
> > tag or definition for the DBD files that would
> differentiate between
> > vxWorks and  RTEMS?
> > I'm using Epics 3.14.8.2.
> DBD files are universal, meaning that we don't create a
> separate expanded DBD file for each target architecture we're
> building for; in fact they get expanded inside the O.Common
> directory which all arch's use.  If you have some DBD entries
> that are specific to a particular architecture, you've going
> to have to create a seperate expanded DBD file for that arch.
>  However this isn't generally as hard as it might seem, since
> you can use variable substitutions in the Makefile to create
> the various different versions without duplicating
> everything.  Here's an example snippet, untested though since
> I'm at home right now:
> PROD_IOC = app
> DBD += unix.dbd rtems.dbd vxworks.dbd
> common_DBD += base.dbd
> common_DBD += allArchs.dbd
> unix_DBD += $(common_DBD)
> unix_DBD += unixOnly.dbd
> rtems_DBD += $(common_DBD)
> rtems_DBD += rtemsOnly.dbd
> vxworks_DBD += $(common_DBD)
> vxworks_DBD += vxworksOnly.dbd
> # <name>_registerRecordDeviceDriver.cpp is created from <name>.dbd
> app_SRCS_DEFAULT += unix_registerRecordDeviceDriver.cpp
> app_SRCS_RTEMS += rtems_registerRecordDeviceDriver.cpp
> app_SRCS_vxWorks += vxworks_registerRecordDeviceDriver.cpp
> app_SRCS_DEFAULT += appMain.cpp
> app_LIBS += $(EPICS_BASE_IOC_LIBS)
> HTH,
> - Andrew
Re: Multiple target os-class application build Andrew Johnson
Prev: Re: Minor VLinac compilation problem on OS X 10.5? Eric Norum
Next: RE: TTL output with soft IOC on Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Multiple target os-class application build Andrew Johnson
Next: Re: Multiple target os-class application build Sue Witherspoon
