1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: calc record LINK error
To: [email protected]
Date: Tue, 26 Feb 2008 10:29:10 +0100
On Friday 22 February 2008 19:31, Emmanuel Mayssat wrote:
> The first thing I would try is to change the CP flags into a NPP.
> It should work in your case, given the value of your calc's SCAN and the
> fact that all of your records are located in the same IOC.
> The difference between CP and NPP (you may already know that) is that
> you use a channel access link (monitor) or a database link. Those are
> two fundamentally different ways to fetch the value of a PV.
Since the OP used CP flag and not CPP, I would assume that he wants to
process both periodically and on monitor.
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
calc record LINK error Leicester, PJ (Pete)
Re: calc record LINK error Emmanuel Mayssat
Prev: Re: Multiple target os-class application build Andrew Johnson
Next: Re: Initialize multi-element field Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: calc record LINK error Emmanuel Mayssat
Next: calc record LINK error Leicester, PJ (Pete)
