1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: calc record LINK error
To: "Leicester, PJ (Pete)" <[email protected]>
Cc: [email protected]
Date: Fri, 22 Feb 2008 10:31:39 -0800
Pete,
The first thing I would try is to change the CP flags into a NPP.
It should work in your case, given the value of your calc's SCAN and the
fact that all of your records are located in the same IOC.
The difference between CP and NPP (you may already know that) is that
you use a channel access link (monitor) or a database link. Those are
two fundamentally different ways to fetch the value of a PV.
Let us know how it went,
E
On Wed, 2008-02-20 at 14:28 +0000, Leicester, PJ (Pete) wrote:
> record(calc, "BL22I-AL-SLITS-02:MOTORSTA") {
>   field(SCAN, "1 second")
>   field(CALC, "(A|B|C|D)>0?1:0")
>   field(INPA, "BL22I-AL-SLITS-02:X:PLUS.MOVN CP MS")
>   field(INPB, "BL22I-AL-SLITS-02:X:MINUS.MOVN CP MS")
>   field(INPC, "BL22I-AL-SLITS-02:Y:PLUS.MOVN CP MS")
>   field(INPD, "BL22I-AL-SLITS-02:Y:MINUS.MOVN CP MS")
>   field(ACKT, "NO")
Re: calc record LINK error Benjamin Franksen
calc record LINK error Leicester, PJ (Pete)
Prev: FW: Problem with soft motor record Rarback, Harvey
Next: Re: Initialize multi-element field Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: calc record LINK error Leicester, PJ (Pete)
Next: Re: calc record LINK error Benjamin Franksen
