1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Initialize multi-element field
To: Dehong Zhang <[email protected]>
Cc: [email protected]
Date: Fri, 22 Feb 2008 13:08:50 -0600
Dehong Zhang wrote:
Could somebody please advice on how to initialize a multi-element
field when calling dbLoadRecords?
Thanks and best regards,
Dehong
I think this can't be done, because at the time dbLoadRecords() runs, the memory that will eventually hold array values has not been allocated. (Even if the memory were allocated, I think there is no code in dbStaticLib to write to it. You must use run-time database access.) I think the earliest time you can write array values is after database initialization (i.e., initHookAfterInitDatabase).
The easiest and closest thing I know of to what you want would be to use
autosave to restore the array values.  You can do this whether or not
autosave is also used to save those values (i.e., you can write an
autosave .sav file by hand).
Here's an example .sav file that will restore a two-element array,
(assuming that autosave is included in the ioc's software).
   # save/restore V4.9
   xxx:myArray @array@ { "1.0" "2.3" }
   <END>
(Note the above file must end with '\n' or "\r\n".)
If the above file is named 'myArrays.sav', and is located in the directory,
<myIocDir>, you can get autosave to restore it by including the following
commands in st.cmd, before iocInit:
   set_savefile_path("<myIocDir>","")
   set_pass1_restoreFile("myArrays.sav")
Here's a link to the autosave module:
http://www.aps.anl.gov/bcda/synApps/autosave/autosave.html
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: Initialize multi-element field Benjamin Franksen
Initialize multi-element field Dehong Zhang
Prev: Re: calc record LINK error Emmanuel Mayssat
Next: Re: TTL output with soft IOC on Linux Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Initialize multi-element field Dehong Zhang
Next: Re: Initialize multi-element field Benjamin Franksen
