1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Initialize multi-element field
To: [email protected]
Date: Fri, 29 Feb 2008 12:28:09 +0100
On Wednesday 27 February 2008 22:52, Maren Purves wrote:
> Andrew Johnson wrote:
> > Benjamin Franksen wrote:
> >> Similar remarks apply, BTW, to other EPICS tools. For instance, I
> >> noticed in the past that dbExpand silently ignores the last line of a
> >> dbd include file if it doesn't end in a newline. This has caused
> >> endless grief to Windows users, as editors for Windows generally don't
> >> automatically add a newline at the end.
> >> If this hasn't already been fixed, I propose to put it on the list of
> >> things to be done before the next release of base. I'd say chances
> >> that people rely on the faulty behaviour are practically zero.
> > I would have no problem in including a fix for that in base, I just
> > can't see how to modify dbStaticLib to do it myself.  Patches from
> > Flex/Antelope experts welcomed.
> IMHO they should fix windows rather than that we should break something
> else to accommodate it.
Maren:
I have two questions:
(1) How exactly does 'something else' break if we fix this (which I regard
as a bug) in dbStaticLib?
(2) Do you really regard it as correct behaviour (and rather think Windows
is broken) if a tool that processes a text file silently ignores the last
line whenever it misses a trailing newline? Note that this last line is
visible in /any/ text editor or text viewer on any platform. It is merely
a /convention/ that (many, not all) Unix editors automatically add a
newline when the file is saved.
Andrew:
I will investigate how to do this.
Cheers
Ben
Re: Initialize multi-element field Maren Purves
Initialize multi-element field Dehong Zhang
Re: Initialize multi-element field Andrew Johnson
Prev: Re: Initialize multi-element field Benjamin Franksen
Next: RE: floating point problem in CA? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Initialize multi-element field Maren Purves
Next: Re: Initialize multi-element field Maren Purves
