1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: floating point problem in CA?
To: "'Heinrich du Toit'" <[email protected]>
Cc: "'EPICS Techtalk'" <[email protected]>
Date: Fri, 29 Feb 2008 08:23:54 -0700
In recent versions of base EPICS_CONVERSION_REQUIRED is set typically in
"base/src/libCom/osi/os/default/osdWireFormat.h". It is defined only if byte
swapping is needed or if the local floating point format isn't IEEE FP.
I will defer your other questions to Janet.
Jeff
#if EPICS_BYTE_ORDER != EPICS_ENDIAN_BIG || EPICS_FLOAT_WORD_ORDER !=
EPICS_BYTE_ORDER
#   if ! defined ( EPICS_CONVERSION_REQUIRED )
#       define EPICS_CONVERSION_REQUIRED
#   endif
#endif
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Heinrich du Toit
> Sent: Thursday, February 28, 2008 10:55 PM
> Cc: EPICS Techtalk
> Subject: Re: floating point problem in CA?
> Thanks for all your help guys...
> In the end it seemed that I had to get -mcpu=arm9 to the compiler.
> I also added -marm but I'm not sure what it does really.
> Seems that without -mcpu=arm9 the compiler doesn't generate correct
> 8-bit codes and that means that some of the conversions doesn't work
> correctly. In convert.cpp I think.
> So my last question is.
> Where exactly SHOULD I put there command in the config files?
> Currently I've put:
> ARCH_DEP_CFLAGS += -mcpu=arm9 -marm
> ARCH_DEP_CPPFLAGS += -mcpu=arm9 -marm
> inside os/CONFIG.Common.linux-arm
> A few other things I don't understand:
> in convert.cpp there is EPICS_CONVERSION_REQUIRED...
> where is this actually controlled - on or off??
> I had to disable the "export GCC_EXEC_PREFIX" in the epics config files
> before my compiler decided to actually find cc1.
> weird.
> Heinrich du Toit wrote:
> > Hi
> > This is weird and I'm not really sure how to track it down.
> > I have an embedded ARM board. I've compiled EPICS onto that.
> > I run vlinac (just to get something ) on my host PC (x86)
> > Then I take an ai variable. (in other words a floating point thing)
> > If I say from the ARM board caput  pvname value
> > Then the correct value gets into the pv on my host pc.
> > But.. the wrong value gets back via channel access.
> > if I caget the value I get the wrong answer.
> > It seems that the network byte order is done wrongly maybe.. I'm not
> > sure.
> > If I put 1.0
> > and then get again I get: 5.29981e-315
> > Which is almost like the wrong network byte order but not exactly it
> > seems.
> > It could be that somewhere along the lines something thinks double is
> > 6 bytes only (rather than 8) and then also swaps the byte order.
> > Maybe there is an htons or something missing somewhere in the code?
> > But how this is possible baffles me. :/
> > I've written a small program to test the structure and layout off
> > "double" on both my PC and the ARM. it seems identical to me.
> > If anybody has any idea how I can "check" this or try and find the
> > problem it would be help full.
> > I am aware that the problem is not necessarily in epics but could be
> > in the compiler options or something like that.
> > thanks
> > -Heinrich
floating point problem in CA? Heinrich du Toit
Re: floating point problem in CA? Heinrich du Toit
Prev: Re: Initialize multi-element field Benjamin Franksen
Next: Record loop issue Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: floating point problem in CA? Heinrich du Toit
Next: FW: floating point problem in CA? Jeff Hill
