1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Record loop issue
To: epics <[email protected]>
Date: Fri, 29 Feb 2008 10:49:18 -0800
I have been struggling with a record loop.
What is the best way to implement the following.
I have a network based Analog output device type.
I want to have the option of using that device as a TTL binary output.
I want the driver to be "smart".
Let's assume I have the following records:
ao, ai, mbbo mbbi (3-state logic high/low/undefined)
If I change the mbbo to high, the ao is set to 3.7v
If I change mbbo to low, ao is set to 1.0v
The ai is readback and mbbi is computed based on the value of ai
Now, I would like the mbbo to reflect the value of the ao
If ao is set to .5, mbbo is reset to low
If ao is set to 2.5, mbbo is undefined
If ao is set to 4.7, mbbo is set to high.
The issue is that if in the latter case mmbo is set to high, ao will be
changed from 4.7 to 3.7v. If mbbo is set to low, ao is switched back to
1v.
Is the sync'ing of ao and mbbo an unreasonable request?
If not, how would you do that?
Emmanuel
Re: Record loop issue Tim Mooney
Re: Record loop issue Luedeke Andreas
Prev: RE: floating point problem in CA? Jeff Hill
Next: Re: Initialize multi-element field Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: floating point problem in CA? Andrew Johnson
Next: Re: Record loop issue Tim Mooney
