1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with gateway
To: Dehong Zhang <[email protected]>
Cc: [email protected]
Date: Tue, 11 Mar 2008 07:41:39 -0500
Hi Dehong,
On the client side try setting the environment variable:
EPICS_CA_SERVER_PORT 6064
before starting the client or trying, for example:
caget gateway.connected
Hope this helps,
Marty
Dehong Zhang wrote:
I am trying to set up a gateway (v2_0_2_1 with epics 3_14_8), am having
trouble.  It complains about:
CAC: Unable to connect because "Invalid argument"
Mar 10 11:39:19 !!! Errlog message received (message is above)
My pv list is called "gateway.pvlist".  It contains:
EVALUATION ORDER ALLOW, DENY
Crate1.*        ALLOW
bpm36.*          ALLOW
# Convert old Gateway internal process variable names
gateway\.\(.*\)            ALIAS     gateway:\1
gateway\.\(.*\)Flag        ALIAS     gateway:\1Flag          GatewayAdmin
gateway\.alive             ALIAS     gateway:connected
gateway\.postEventRate     ALIAS     gateway:clientPostRate
The access list is called "gateway.access".  It has:
ASG(DEFAULT) {
   RULE(1,READ)
The command I use is:
./gateway -sport 6064 -cport 5065 -pvlist ./gateway.pvlist -prefix "gateway" -access ./gateway.access
I cannot even access the internal PVs like:
gateway:pvtotal
gateway:active
Please enlighten me.
Thanks and best regards,
Dehong
Re: Problem with gateway Dehong Zhang
Prev: RE: Building MEDM Hammonds, John P.
Next: RE: Building MEDM David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem with gateway Dehong Zhang
Next: Re: Problem with gateway Dehong Zhang
