1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with gateway
To: "Martin L. Smith" <[email protected]>
Cc: [email protected]
Date: Tue, 11 Mar 2008 13:57:26 -0500
Hi Marty,
Thank you very much for your advice!  The problem turned out to be the
-cport option.  It should have been 5064, because I did not specify the
port to use on my frontend (IOC).  And I misunderstood the ALIASes, then
ASL etc.  Now the path is through.
However I still have 2 issues:
1. multi-element PVs timeout -- I tried longer timeouts, no help;
Read operation timed out: some PV data was not read.
bpm36.MINT
    Data type:      DBR_FLOAT (native: DBF_FLOAT)
    Element count:  4096
    Value:          0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
CA.Client.Exception...............................................
    Warning: "Virtual circuit disconnect"
    Context: "op=0, channel=bpm36.MINT, type=DBR_FLOAT, count=4096, ctx="atflap2.fnal.gov:6064""
    Source File: ../getCopy.cpp line 82
    Current Time: Tue Mar 11 2008 13:54:58.77628354
2. still get
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "gateway_vctotal", Connecting to: atflap2.fnal.gov:6064, Ignored: 0.0.0.1:5"
    Source File: ../cac.cpp line 1224
    Current Time: Tue Mar 11 2008 11:31:44.913328026
   on the client end.  On the gateway side, still get
CAC: Unable to connect because "Invalid argument"
Mar 11 11:33:54 !!! Errlog message received (message is above)
Mar 11 11:33:54 Warning: Virtual circuit disconnect 0.0.0.1:5
Mar 11 11:33:54 Warning: Virtual circuit disconnect 0.0.0.2:5
And there is a strange udp connection (on the gateway node):
udp        0      0 atflap2.fnal.gov:32889      255.255.255.255:5065        ESTABLISHED
It seems somehow I am creating a loopback -- but I am not specifying 5065 anywhere.
Please give me more advices.
Thanks and best regards,
Dehong
----- Original Message -----
Date: Tuesday, March 11, 2008 7:41 am
To: Dehong Zhang <[email protected]>
> Hi Dehong,
> On the client side try setting the environment variable:
> EPICS_CA_SERVER_PORT 6064
> before starting the client or trying, for example:
> caget gateway.connected
> Hope this helps,
> Marty
> Dehong Zhang wrote:
> > Hi,
> > I am trying to set up a gateway (v2_0_2_1 with epics 3_14_8), am having
> > trouble.  It complains about:
> > Mar 10 11:39:19 !!! Errlog message received (message is above)
> > My pv list is called "gateway.pvlist".  It contains:
> > EVALUATION ORDER ALLOW, DENY
> > Crate1.*        ALLOW
> > bpm36.*          ALLOW
> > # Convert old Gateway internal process variable names
> > gateway\.\(.*\)            ALIAS     gateway:\1
> > gateway\.\(.*\)Flag        ALIAS     gateway:\1Flag          GatewayAdmin
> > gateway\.alive             ALIAS     gateway:connected
> > gateway\.postEventRate     ALIAS     gateway:clientPostRate
> > The access list is called "gateway.access".  It has:
> > ASG(DEFAULT) {
> >    RULE(1,READ)
> > The command I use is:
> > ./gateway -sport 6064 -cport 5065 -pvlist ./gateway.pvlist -prefix
> "gateway" -access ./gateway.access
> > I cannot even access the internal PVs like:
> > gateway:pvtotal
> > gateway:active
> > Please enlighten me.
> > Dehong
Problem with gateway Dehong Zhang
Re: Problem with gateway Martin L. Smith
Prev: Re: EPICS support for 2-D detectors/cameras Kate Feng
Next: RE: [APS Beamline_controls] EPICS support for 2-D detectors/cameras l.lurio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with gateway Martin L. Smith
Next: PLC Ethernet Driver for the IDEC MicroLogix 1100 Luchini, Kristi
