1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [APS Beamline_controls] EPICS support for 2-D detectors/cameras
To: "'Kate Feng'" <[email protected]>, "'tieman'" <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 11 Mar 2008 14:17:05 -0500
I think it would be nice to have the ability to transfer images through
epics, but I don't think it is a good idea to make this the sole means to
save images.  For a really fast system you probably want to write directly
to a local RAID array using a dedicated controller.  I think this could be
at least 10 x's faster than the 20 Mbytes/s you list.
Larry
Laurence Lurio
Associate Professor
Department of Physics
Northern Illinois University
Phone: 815 753-6492
Cell:     815 260-4900
Email: [email protected]
-----Original Message-----
[mailto:[email protected]] On Behalf Of Kate
Feng
Sent: Tuesday, March 11, 2008 1:56 PM
To: tieman
Cc: [email protected]; [email protected]
Subject: Re: [APS Beamline_controls] EPICS support for 2-D detectors/cameras
tieman wrote:
> I've thought about the standard EPICS IOC route.  The Image Server was
> always an application first and a PV server second.  I still believe
> there is value in that philosophy but can see the value in going
> standard EPICS.
> I don't see a danger in sticking with the Portable Channel Access
> Server.  There's enough code reliant on it now that I don't see it
> going away.  It does not suffer from the 16K barrier if built to avoid
> it but I generally disagree with EPICS as a means to move image data.
> I've already done a small amount of preliminary work in developing a
> new code base using the PCAS but it's nothing that can't be thrown away.
It is always a good idea to constantly seek improvement on EPICS.
However, I am not unhappy about its CA performance so far.  Sometimes,
its perfromance is coupled with the hardware, software and PC that
is used in your system.
In Nov. 2007, I was able to "display real-time image"  at an average
of  20 Mbytes/sec (a max. of 22 Mbytes/sec) while the camera
was transferring the image data at 28 Mbytes/sec to the system
memory via the 1GHz network. The performance is up by 33 % since
the paper was published in ICALEPCS07 conference, which was held
in Oct..  See
http://accelconf.web.cern.ch/accelconf/ica07/PAPERS/WPPB12.PDF
The system configuration is mvme5500/firewire/Linux PC.
The better news is that I do not think I hit the bottleneck yet.
1) I could still improve the mvme5500 BSP that I wrote to have higher
performance.
2)  The perfromance is estimated to be at least twice higher with the
mvme6100 support  in the "disco" BSP, which I derived
from the mvme5500 BSP that I wrote.  "disoc" BSP supports the discovery
based board such as mvme5500 and mvme6100.
However, the analysis of 1) and 2) is not a high priority task to me
presently.
Only the sky is the limit.
Cheers,
Kate
APS Beamline_controls mailing list
post: [email protected]
request: [email protected]
http://www.aps.anl.gov/mailman/listinfo/beamline_controls
Re: [APS Beamline_controls] EPICS support for 2-D detectors/cameras Kate Feng
RE: [APS Beamline_controls] EPICS support for 2-D detectors/cameras Mark Rivers
Re: EPICS support for 2-D detectors/cameras tieman
Re: EPICS support for 2-D detectors/cameras Kate Feng
Prev: Re: Problem with gateway Dehong Zhang
Next: Re: [APS Beamline_controls] EPICS support for 2-D detectors/cameras Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS support for 2-D detectors/cameras Kate Feng
