1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building MEDM
To: "David Dudley" <[email protected]>, <[email protected]>
Date: Tue, 11 Mar 2008 10:34:02 -0500
One of these specifies netbsd-x86 as the host architecture, the other specifies that this is also target platform.
John
-----Original Message-----
Sent: Tue 3/11/2008 9:59 AM
To: [email protected]
Subject: Re: Building MEDM
OK, found the problem
The file is supposed to be named 'CONFIG_SITE.<arch>.<arch>', and I had
it named 'CONFIG_SITE.<arch>'. A file named 'CONFIG_SITE.netbsd-x86'
doesn't match 'CONFIG_SITE.netbsd-x86.netbsd-x86'.  Why is arch repeated
twice???  Is that for cross-compiling?
David
>>> "David Dudley" <[email protected]> 3/11/2008 9:45 AM >>>
Yes, I'm using the new "Extensions Top" config files.
I'm working with medm3_1_2_1.  Please understand that this is part of
my project to port Epics to NetBSD, so I'm sure it's just something
that
is not being picked up by someone.
I'll capture a logfile of the compile, next time I compile the
package,
but the command I use is simply to move to the extensions directory,
and
type 'gmake' (NetBSD uses normal BSD 'make' as it's default make
program).
David
>>> "J. Lewis Muir" <[email protected]> 3/11/2008 9:17 AM >>>
On 3/11/08 9:35 AM, David Dudley wrote:
> Oh, so it's that file.  I was looking for something in base.  I have
> that file, and I have the settings set correctly in it.  However,
when I
> get over to the build for MEDM, the variables appear to be blank.
This
> is only happening on MEDM, not on any of the other extensions.
> David
Hi, David.
What version of EPICS base are you using?
Are you using the new "Extensions Top" config files from
  http://www.aps.anl.gov/epics/extensions/configure/index.php
What version of MEDM are you trying to compile?
Could you send the commands you're using to compile MEDM and their
output?
Lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
Building MEDM David Dudley
RE: Building MEDM Hammonds, John P.
RE: Building MEDM David Dudley
Re: Building MEDM J. Lewis Muir
Re: Building MEDM David Dudley
Prev: Re: Building MEDM David Dudley
Next: Agilent E5810 GPIB Gateway issue Robert Emery
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
