1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Severity of I/O interrupt records
To: <[email protected]>
Date: Tue, 18 Mar 2008 13:26:58 -0700
I am using streamdevice to communicate with a VME crate controller.  One record sends a query string to the crate and receives a string as a reply.  The reply string contains a lot of information and needs to be mapped to several records.  The records that receive this information are all streamdevice records with I/O interrupt processing.  This all works.
My problem is that I want the severity of all the I/O interrupt records to be set to invalid if there is a problem with the communication to the crate.  The record that sends the query string has invalid severity in this case.  Can anyone suggest a nice way to propagate that invalid severity to all the I/O interrupt records?  I thought about disabling the records, but I think I would need to process the records to make this work, and I don't know how to cause I/O interrupt records to process.  Is there an asyn option that will cause I/O interrupt records to process after a connection problem?
thank you,
Stephen
RE: Severity of I/O interrupt records Shepherd, EL (Emma)
Re: Severity of I/O interrupt records Tim Mooney
RE: Severity of I/O interrupt records Mark Rivers
Prev: RE: Listen to multiple events Allison, Stephanie
Next: Re: Listen to multiple events Korhonen Timo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM cursors. Terry Carlino
Next: RE: Severity of I/O interrupt records Shepherd, EL (Emma)
