1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Severity of I/O interrupt records
To: "Schuh, Stephen" <[email protected]>
Cc: [email protected]
Date: Wed, 19 Mar 2008 08:51:43 -0500
Stephen,
If the I/O-Interrupt-scanned records have input links to the record
that sends the query, and if those links have the attribute "MS",
then the I/O-Interrupt-scanned records should get a link alarm from
the querying record.  The SDIS input link seems a likely candidate for
the job.  I think you want the records to process, so they can post
their discontent.  This means the SDIS links should go to some field
whose value won't match the linker's DISV value.  If this works, you'd
better comment the strategy in the database, because nobody will guess
that the SDIS links are only being used for alarm propagation.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Schuh, Stephen wrote:
I am using streamdevice to communicate with a VME crate controller.  One
record sends a query string to the crate and receives a string as a reply.
The reply string contains a lot of information and needs to be mapped to
several records.  The records that receive this information are all
streamdevice records with I/O interrupt processing.  This all works.
My problem is that I want the severity of all the I/O interrupt records to be
set to invalid if there is a problem with the communication to the crate.
The record that sends the query string has invalid severity in this case.
Can anyone suggest a nice way to propagate that invalid severity to all the
I/O interrupt records?  I thought about disabling the records, but I think I
would need to process the records to make this work, and I don't know how to
cause I/O interrupt records to process.  Is there an asyn option that will
cause I/O interrupt records to process after a connection problem?
thank you, Stephen
Severity of I/O interrupt records Schuh, Stephen
Prev: sysAtReboot and epicsExit Chris Slominski
Next: Re: sysAtReboot and epicsExit Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Severity of I/O interrupt records Dirk Zimoch
Next: RE: Severity of I/O interrupt records Mark Rivers
