1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Severity of I/O interrupt records
To: "Shepherd, EL (Emma)" <[email protected]>
Cc: [email protected]
Date: Thu, 20 Mar 2008 09:25:15 +0100
Hi all,
Unfortunately, Emma is wrong. Because of the way how %(myRecord.fieldName) is implemented, myRecord is never processed when the read does not succeed. I just don't get to the point to find out about myRecord when there is no input to parse.
Also forwarding connection problems to I/O Intr records is not don in StreamDevice yet. Because it is not supported by asyn, I would have to add a yet another hack and have my own list of I/O Intr connected to any particular asyn port/address. That is something I can probably do.
Dirk
Shepherd, EL (Emma) wrote:
Hi Stephen,
One thing you could do is to change your implementation slightly.  Make
your I/O interrupt records Passive, and change your protocol to
explicitly map each part of the message to the required records using
the "%(myRecord.fieldName)" syntax of format converters.
I'm fairly sure this should make the records go invalid if communication
fails... but someone correct me if I'm wrong.
Emma
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Schuh, Stephen
Sent: 18 March 2008 20:27
To: [email protected]
Subject: Severity of I/O interrupt records
I am using streamdevice to communicate with a VME crate controller. One record sends a query string to the crate and receives a string as a reply. The reply string contains a lot of information and needs to be mapped to several records. The records that receive this information are all streamdevice records with I/O interrupt processing. This all works.
My problem is that I want the severity of all the I/O interrupt records to be set to invalid if there is a problem with the communication to the crate. The record that sends the query string has invalid severity in this case. Can anyone suggest a nice way to propagate that invalid severity to all the I/O interrupt records? I thought about disabling the records, but I think I would need to process the records to make this work, and I don't know how to cause I/O interrupt records to process. Is there an asyn option that will cause I/O interrupt records to process after a connection problem?
thank you,
Stephen
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
</FONT></DIV>
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
RE: Severity of I/O interrupt records Shepherd, EL (Emma)
Prev: Re: EPICS: Selecting a Text Error Message Emmanuel Mayssat
Next: CALC expression feature request Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Severity of I/O interrupt records Shepherd, EL (Emma)
Next: Re: Severity of I/O interrupt records Tim Mooney
