Dear Jeff, dear Andrew,
thank you very much for analyzing the problem. I have learned a lot
more. We found out - using host name and port number - which client
caused the problem. We stopped it for now.
Apart from that it would be a more relaxed situation if the ioc would be
more robust against such wild running clients.
Bernd
Andrew Johnson schrieb:
Jeff Hill wrote:
What does the first number in parenthesis mean? Something like an
element count. For this sick connection it was 54! Please look at the
attachment.
This means that your client has subscribed (called
ca_create_subscription or
ca_add_event) 54 times! One option of course will be to find the
misbehaved
client (the IP address is in the casr report) and convince its author to
recode his application.
One common bug that can cause such a large number of connections is if
the channel connection callback routine creates a new subscription
whenever a channel connection comes up, even if it already had a
subscription from the last time it connected. The application in
question here appears to be the DESY archiver which is likely to have an
effect on a large number of IOCs, so I would strongly recommend that
this code be reviewed for incorrect channel subscription logic. A
strong indication that this kind of bug is present is if the number
increases over an IOC reboot and decreases over an application restart.
The best
would be to disconnect all CA connections and give back (at least a part
of) the additionally allocated memory back to the system pool.
We don't currently have an option to do this, but considering that
vxWorks
memory allocation is much better than in the past perhaps one option that
should be considered for R3.15 is to use free lists dedicated to each
client
that are returned to system pool when the client disconnects.
Note that this IOC is running R3.13.10 on vxWorks 5.3.1; if my memory is
correct, this is using the old (pre-SENS) TCP/IP stack, so its network
buffer management is very different to the SENS stack which has fixed
buffer sizes. The earlier stack could (and did) call malloc() to get
new buffers after initialization time.
Also, if the memory is being used up by a multiple subscription bug in a
client this kind of memory pool rework would make no difference anyway.
- Andrew
- RE: Memory Problem related to CA? Jeff Hill
- Memory Problem related to CA? Schoeneburg, Bernd
- Re: Memory Problem related to CA? Schoeneburg, Bernd
- Re: Memory Problem related to CA? Andrew Johnson
CALC expression feature request Benjamin Franksen
Re: EPICS: Selecting a Text Error Message Bill Nolan
<2008>
2025
2026
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
