1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: New Perl 5 CA module
To: EPICS tech-talk <[email protected]>
Date: Thu, 03 Apr 2008 10:58:17 -0500
I've been working on a CA client library interface module for Perl 5, since all of the existing ones I know of use EZCA (which I don't like). A version of this code will probably be included in Base R3.14.10, but I'm making it available now since it works fine with R3.14.9 and I would like some outside testing first.
For test and example purposes I have reimplemented the cainfo, caget, caput and camonitor programs from Base in Perl, although my versions are not as comprehensive as Ralph's C originals. The code has been tested on Solaris, Linux and Darwin/Mac OS X; I have no idea whether it will build or run on Windows, but I'd be interested in feedback or patches if someone manages to make it work there.
Requires: Perl 5.8.x, tested on 5.8.6 and 5.8.8.
The source code can be found in the EPICS Modules Download area at
  http://www.aps.anl.gov/epics/download/modules/cap5-0.1.tgz
Documentation (using Perl's POD format) is included in the package and will be converted to HTML at build time, or it can be read online at
http://www.aps.anl.gov/epics/modules/soft/cap5/
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
Prev: Re: cross subnet CA communication Sue Witherspoon
Next: Re: cross subnet CA communication Sue Witherspoon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cross subnet CA communication Paul Sichta
Next: Building motor6-3 record David Morris
