First, thanks to all who gave me helpful suggestions. I have found the
problem! When we converted from 3.13.2 to 3.14 I "stumbled upon" the
fact that the iocInit interface had changed such that it no longer took
"resource.def" as an argument. What I didn't realize is that the
environment variables that are set in the resource.def must be set
before iocInit is called and that even though you can dynamically change
the EPICS_CA_ADDR_LIST on the ioc it has no effect without a reboot.
So if there are still any folks who are using the old iocInit
"resource.def" and need to convert. Beware and use:
<resource.def
iocInit
Cheers!
Sue
Sue Witherspoon wrote:
In the startup are the lines:
hostAdd "devnet", "129.57.228.1"
# use this for IOC's which are on 129.57.{228,229,230,231}
routeAdd "0.0.0.0", "devnet"
I couldn't run tcpdump but I could run casw on the 236 subnet and I'm
getting no broadcasts from iocfb1.
I can ping from each IOC and see the other IOC.
When I switch between different kernels and EPICS I've had to burn the
flash to go from tornado 1.0.1 to 2.2.1. And then change links that
point to the different versions.
My original thought was there is some parameter in the kernel or epics
that I'm missing because I am communicating from the 230 to the 236
network if both IOCs are running epics 3.13 and tornado 1.0.1. And
within a subnet I can communicate regardless of the kernel or EPICS
version.
-Sue
Paul Sichta wrote:
I've added the following to the st.cmd boot file. The IP is the IP
of the gateway for the subnet of the IOC server.
# for beyond-subnet CA clients
routeAdd "0", "198.35.10.10"
-ps
Geoff Savage wrote:
Can you run tcpdump on a linux box in the 236 subnet to look for the
broadcast from iocfb1?
Does a ping from each IOC see the other IOC?
What do you do to switch between the different kernels and EPICS
versions when you boot? Are you missing a non-EPICS configuration in
this process?
Geoff
On Apr 2, 2008, at 12:33 PM, Sue Witherspoon wrote:
Greetings,
I have a curious problem concerning multi-subnet connectivity when
converting from Epics 3.13.2 to Epics 3.14.8.2. Using the same
network setup and database the 3.13 db can communicate across
subnets while the 3.14 db gets a link error.
Again, if iocfb1 is running Epics 3.13.2 and Tornado 1.0.1 then
there is no link error and there's communication between the two
subnets, but if iocfb1 is running Epics 3.14.8.2 and Tornado 2.2.1
then I get a link error. Any suggestions?
Here is my setup:
iocmc1 129.57.236.20 iocfb1 129.57.230.101
Epics 3.13.2 Epics 3.14.8.2
mvme-2700 mvme-2700
Tornado 1.0.1 Tornado 2.2.1
database record on iocfb1 129.57.230.101
record(ai,"iocfb1:mc1com1") {
field(DESC,"analog input record")
field(SCAN,"Passive")
field(INP,"iocmc1:heartbeat.VAL")
database record on iocmc1 129.57.236.20
record(calc,"iocmc1:heartbeat") {
field(DESC,"calculation record")
field(SCAN,"1 second")
resource.def file for iocfb1
putenv ("EPICS_CA_AUTO_ADDR_LIST = YES")
putenv ("EPICS_CA_ADDR_LIST = 129.57.239.255")
bootParams:
boot device : dc0
processor number : 0
host name : devfs
file name : /devsite/op/iocs/iocfb1/vx/vxWorks.st
inet on ethernet (e) : 129.57.230.101:fffffc00
inet on backplane (b):
host inet (h) : 129.57.228.40
gateway inet (g) : 129.57.228.1
user (u) : vxwrks
ftp password (pw) (blank = use rsh):
flags (f) : 0x80
target name (tn) : iocfb1
startup script (s) : /devsite/op/iocs/iocfb1/startup
resource.def file for iocmc1 EPICS_CA_ADDR_LIST DBF_STRING
"129.57.211.255 129.57.243.255 129.57.255.10"
bootParams:
boot device : dc
host name : opsfs
file name : /opssite/op/iocs/iocmc1/vx/vxWorks.st
inet on ethernet (e) : 129.57.236.20:fffffc00
host inet (h) : 129.57.236.40
user (u) : vxwrks
flags (f) : 0x80
target name (tn) : iocmc1
startup script (s) : /opssite/op/iocs/iocmc1/startup
- cross subnet CA communication Sue Witherspoon
- Re: cross subnet CA communication Geoff Savage
- Re: cross subnet CA communication Sue Witherspoon
New Perl 5 CA module Andrew Johnson
Building motor6-3 record David Morris
<2008>
2025
2026
Re: cross subnet CA communication Paul Sichta
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
