Hi Burkhard,
int32Driver.c is a simulated driver, so it does not do real I/O. The int32Write and int32Read functions write and read the data from a private structure in the driver.
If you want a simple example of a VME register-based asynInt32 driver you can look at my driver for the Systran DAC-128V. It is here:
http://cars.uchicago.edu/software/epics/dac128V.html
Note that the source code for that driver is fine, but the documentation is out of date, it still refers to MPF, which predated of asyn.
Here is the asynInt32 write function in that driver:
static asynStatus writeInt32(void *drvPvt, asynUser *pasynUser,
epicsInt32 value)
drvDac128VPvt *pPvt = (drvDac128VPvt *)drvPvt;
int channel;
pasynManager->getAddr(pasynUser, &channel);
if(value<0 || value>pPvt->maxValue || channel<0 || channel>pPvt->lastChan)
return(-1);
pPvt->regs[channel] = value;
asynPrint(pasynUser, ASYN_TRACEIO_DRIVER,
"drvDac128V, port %s, wrote %d to channel %d\n",
pPvt->portName, value, channel);
return(0);
Sent: Tue 4/8/2008 8:49 AM
To: '[email protected]'
Subject: Example for VME reg-based port driver for asyn on Linux?
Hi
I'm in the process of converting applications from VxWorks to Linux.
I have a multitude of VME boards with write/read registers (no
interrupts). On VxWorks I usually have built subRecords to access the
registers on the boards.
Now we use Concurrent single board cpus in VME (running linux) where the
use of mapping registers is restricted due to the large address space of
the cpus. So I would like to map the individual boards in an orderly
fashion via some register-board-base-addr call and then use for instance
asyn int32 support.
I have looked in the example int32Driver.c but can't see where the real
I/O is done?
Does anyone have some real example? Or is this sort of overkill?
Many thanks, Burkhard
Dr. Burkhard Kolb
KP1 / GSI
E-Mail: [email protected]
Tel: +49-(6159)-71-2667 / Fax: +49-(6159)-71-2185
Gesellschaft für Schwerionenforschung mbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführer: Professor Dr. Horst Stöcker
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
- Example for VME reg-based port driver for asyn on Linux? Burkhard Kolb
The select record MEDIAN calculation Dennis Armstrong
<2008>
2025
2026
<2008>
2025
2026
