1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cavget of a waveform
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Thu, 10 Apr 2008 13:46:40 -0500
Emmanuel Mayssat wrote:
Hello,
Some of you may be familiar with the cavget alternative to caget.
I am currently trying to cavget a waveform record.
To my surprise, this utility only returns the last value of the
waveform. Is there an option/trick to have cavget, like caget, return
the entire waveform ?
Emmanuel
cavget does not handle waveforms. It returns the first element in the waveform only. What I would suggest is that you use:
sddswget -PVnames=BRF:K5:WaveformCh8 -pipe=out | sdds2stream -pipe=in -col=Waveform
--Bob
cavget of a waveform Emmanuel Mayssat
Prev: cavget of a waveform Emmanuel Mayssat
Next: RE: Windows EPICS problem Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Channel Archiver compiling problem with Xerces XML Library Tasaddaq Ali Khan
