Jeff,
I now have some time to get back to this problem. I've included a bunch of diagnostics, but I cannot see the problem.
I have established that defining EPICS_CA_ADDR_LIST=127.0.0.1 (and not defining EPICS_CA_AUTO_ADDR_LIST) in the shell running the client is sufficient to solve the problem.
If 127.0.0.1 is not in EPICS_CA_ADDR_LIST I cannot connected local PVs. It does not help to set that in the command shell running the IOC, it only works if it is defined for the client.
Here is the output of ipconfig/all. It looks OK to me.
C:\Documents and Settings\epics>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : ferrari
Primary Dns Suffix . . . . . . . : CARS.APS.ANL.GOV
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : CARS.APS.ANL.GOV
APS.ANL.GOV
ANL.GOV
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controller
Physical Address. . . . . . . . . : 00-18-8B-13-7D-BA
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 164.54.160.93
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 164.54.160.1
DNS Servers . . . . . . . . . . . : 164.54.160.12
164.54.160.45
Here is the output of route print on the machine with the problem:
C:\Documents and Settings\epics>route print
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 18 8b 13 7d ba ...... Broadcom NetXtreme 57xx Gigabit Controller - Packet Scheduler Miniport
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 164.54.160.1 164.54.160.93 10
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
164.54.160.0 255.255.255.0 164.54.160.93 164.54.160.93 10
164.54.160.93 255.255.255.255 127.0.0.1 127.0.0.1 10
164.54.255.255 255.255.255.255 164.54.160.93 164.54.160.93 10
224.0.0.0 240.0.0.0 164.54.160.93 164.54.160.93 10
255.255.255.255 255.255.255.255 164.54.160.93 164.54.160.93 1
Default Gateway: 164.54.160.1
Persistent Routes:
None
Here is the output of route print on another Windows machine that does not have any trouble connecting to local PVs. As far as I can see they look identical except for the host local host IP number.
C:\Documents and Settings\rivers.CARS_NT_DOMAIN>route print
Interface List
0x20002 ...00 07 e9 6a 79 ba ...... Intel(R) PRO/1000 MT Network
Connection - Packet Scheduler Miniport
Active Routes:
0.0.0.0 0.0.0.0 164.54.160.1 164.54.160.38 10
164.54.160.0 255.255.255.0 164.54.160.38 164.54.160.38 10
164.54.160.38 255.255.255.255 127.0.0.1 127.0.0.1 10
164.54.255.255 255.255.255.255 164.54.160.38 164.54.160.38 10
224.0.0.0 240.0.0.0 164.54.160.38 164.54.160.38 10
255.255.255.255 255.255.255.255 164.54.160.38 164.54.160.38 1
Persistent Routes:
None
Here is the output of TCPview when EPICS_CA_ADDR_LIST is not defined and there is thus no connection to the IOC application called simDetectorApp.
simDetectorApp.exe:856 TCP ferrari:5064 ferrari:0 LISTENING
simDetectorApp.exe:856 UDP ferrari:1497 *:*
simDetectorApp.exe:856 UDP ferrari:5064 *:*
simDetectorApp.exe:856 UDP ferrari:1498 *:*
simDetectorApp.exe:856 UDP ferrari:1499 *:*
Here is the output of TCPview when EPICS_CA_ADDR_LIST is defined and there is a client connection to the IOC application. The last line shows the client connection.
simDetectorApp.exe:856 TCP ferrari:5064 localhost:1688 ESTABLISHED
Here is the output of cainfo when EPICS_CA_ADDR_LIST is not defined:
C:\Documents and Settings\epics>set EPICS_CA_ADDR_LIST=
C:\Documents and Settings\epics>set EPICS_CA_AUTO_ADDR_LIST=
C:\Documents and Settings\epics>cainfo -s10 13SIM1:cam1:FileName_RBV
Channel connect timed out: '13SIM1:cam1:FileName_RBV' not found.
ca_client_context at 003A3D18 pndRecvCnt=0 ioSeqNo=1
Channel Access Client Context at 003A3E98 for user epics
revision "@(#) EPICS 3.14.8.2, CA Client Library Aug 1 2006"
Hash table with 0 buckets and 0 items of type class tcpiiu installed
connection time out watchdog period 30.000000
Datagram IO circuit (and disconnected channel repository)
repeater port 5065
default server port 5064
Channel Access Address List
164.54.160.255:5064
socket identifier 1756
bytes in xmit buffer 16
shut down command bool 0
recv thread exit signal:
repeater subscribe timer: attempts=0 registered=0 once=0
disconnect governor timer:
search timer delay 0.032000
0 channels with search request pending
0 channels with search response pending
search timer delay 0.064000
search timer delay 0.128000
search timer delay 0.256000
search timer delay 0.512000
1 channels with search response pending
Channel "13SIM1:cam1:FileName_RBV" is disconnected
network IO pointer = 00980048
server identifier 4294967295
search retry number=5
name length=25
search timer delay 1.024000
search timer delay 2.048000
search timer delay 4.096000
search timer delay 8.192000
search timer delay 16.384000
search timer delay 32.768000
search timer delay 65.536000
search timer delay 131.072000
search timer delay 262.144000
Program begin time:
epicsTime: Fri Apr 11 2008 13:24:09.008243293
epicsTime: revision "@(#) EPICS 3.14.8.2, Common Utilities Library Aug 1 2006"
Channel identifier hash table:
Hash table with 512 buckets and 1 items of type class nciu installed
name length=25
name length=25
entries per bucket: mean = 0.001953 std dev = 0.044151 max = 1
IO identifier hash table:
Hash table with 0 buckets and 0 items of type class baseNMIU installed
Beacon source identifier hash table:
Hash table with 0 buckets and 0 items of type class bhe installed
Timer queue:
EPICS threaded timer queue at 003A4F58
epicsTimerQueue with 16 items pending
class searchTimer, state = pending, delay = 0.004087
class searchTimer, state = pending, delay = 0.007467
class searchTimer, state = pending, delay = 0.011513
class searchTimer, state = pending, delay = 0.016706
class searchTimer, state = pending, delay = 0.083627
class searchTimer, state = pending, delay = 0.238962
class searchTimer, state = pending, delay = 1.034945
class searchTimer, state = pending, delay = 3.082937
class searchTimer, state = pending, delay = 7.178929
class disconnectGovernorTimer, state = pending, delay = 8.986641
class repeaterSubscribeTimer, state = pending, delay = 8.986631
class searchTimer, state = pending, delay = 15.370618
class searchTimer, state = pending, delay = 31.754610
class searchTimer, state = pending, delay = 64.522361
class searchTimer, state = pending, delay = 130.058351
class searchTimer, state = pending, delay = 261.130343
reschedule event
exit event
exitFlag = F, terminateFlag = F
IP address to name conversion engine:
ipAddrToAsciiEngine at 003A4928 with 0 requests pending
mutex:
epicsMutexId 003A4DA8 source ..\..\..\src\libCom\osi\epicsMutex.cpp line 197
epicsMutex: win32 critical section at 003A4D88
laborEvent:
exitFlag boolean = 0
exit event:
Default mutex:
epicsMutexId 003A3DF0 source ..\..\..\src\libCom\osi\epicsMutex.cpp line 197
epicsMutex: win32 critical section at 003A3DD0
mutex:
preemptive callback is disabled
there are 0 unsatisfied IO operations blocking ca_pend_io()
the current io sequence number is 1
IO done event:
Synchronous group identifier hash table:
Hash table with 0 buckets and 0 items of type struct CASG installed
Now set the environment EPICS_CA_ADDR_LIST so it will find the PV and try again:
C:\Documents and Settings\epics>set EPICS_CA_ADDR_LIST=127.0.0.1
ca_client_context at 003A3D48 pndRecvCnt=0 ioSeqNo=1
Channel Access Client Context at 003A3EC8 for user epics
Hash table with 512 buckets and 1 items of type class tcpiiu installed
Virtual circuit to "localhost:5064" at version V4.11 state 1
current data cache pointer = 009AAF98 current data cache size = 16384
contiguous receive message count=0, busy detect bool=0, flow control bool=0
eceive thread is busy=0
virtual circuit socket identifier 1672
send thread flush signal:
send thread:
recv thread:
echo pending bool = 0
Connected channels
Channel "13SIM1:cam1:FileName_RBV", connected to server localhost:5064, native type DBF_CHAR, native element count 256,
read access, write access
network IO pointer = 009A63D8
server identifier 10
search retry number=1
name length=25
send thread:
recv thread:
Connected channels
name length=25
repeater port 5065
164.54.160.255:5064
localhost:5064
Program begin time:
epicsTime: Fri Apr 11 2008 13:22:04.670037758
name length=25
name length=25
Hash table with 512 buckets and 1 items of type class bhe installed
CA beacon hash entry for 127.0.0.1:5064 <no period estimate>
beacon number 0, on <undefined>
Timer queue:
EPICS threaded timer queue at 003A4F88
epicsTimerQueue with 17 items pending
class searchTimer, state = pending, delay = 0.018199
class searchTimer, state = pending, delay = 0.024576
class searchTimer, state = pending, delay = 0.088306
class searchTimer, state = pending, delay = 0.216296
class searchTimer, state = pending, delay = 0.472289
class searchTimer, state = pending, delay = 0.984283
class searchTimer, state = pending, delay = 2.008014
class searchTimer, state = pending, delay = 4.056006
class searchTimer, state = pending, delay = 8.152018
class disconnectGovernorTimer, state = pending, delay = 9.959748
class repeaterSubscribeTimer, state = pending, delay = 9.959738
class searchTimer, state = pending, delay = 16.343724
class tcpRecvWatchdog, state = pending, delay = 29.987311
Receive virtual circuit watchdog at 009A64E8, period 30.000000
class searchTimer, state = pending, delay = 32.727444
class searchTimer, state = pending, delay = 65.495436
class searchTimer, state = pending, delay = 131.031428
class searchTimer, state = pending, delay = 262.103150
reschedule event
exit event
ipAddrToAsciiEngine at 003A4958 with 0 requests pending
mutex:
epicsMutexId 003A4DD8 source ..\..\..\src\libCom\osi\epicsMutex.cpp line 197
epicsMutex: win32 critical section at 003A4DB8
laborEvent:
exit event:
Default mutex:
epicsMutexId 003A3E20 source ..\..\..\src\libCom\osi\epicsMutex.cpp line 197
epicsMutex: win32 critical section at 003A3E00
mutex:
IO done event:
Sent: Fri 4/11/2008 10:05 AM
To: Mark Rivers
Subject: RE: Windows EPICS problem
Hi Mark,
As I recall, at a higher interest level, the show function in the CA client
library will dump the CA client's UDP search request destination address
list. That might also be interesting information.
Jeff
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Tuesday, April 08, 2008 6:01 PM
> To: [email protected]; [email protected]; [email protected]
> Subject: Windows EPICS problem
> Folks,
> I'm having a strange problem on a Windows XP machine. I am running a soft
> IOC on that machine, but I can't see its PVs from any local CA client
> (caget, IDL, medm, etc).
> However:
> - CA clients on that Windows machine can see PVs on all other machines on
> the network
> - CA clients on other machines on the network can see PVs on the Windows
> machine
> So the problem is only that local Windows clients can not see the PVs from
a
> soft IOC running on the same computer. This is only happening on this
> computer, not other Windows computers running the same IOC binary. (They
are
> not running at the same time, so it is not a duplicate PV name problem).
> None of the EPICS environment variables are set except:
> EPICS_CA_MAX_ARRAY_BYTES=10000000
> EPICS_DISPLAY_PATH=P:/epics/adl
> The Windows Firewall is not running, nor is any other firewall that I am
> aware of.
> What could be wrong? Of course I need this machine to be running an EPICS
> demo tomorrow!
> Help!
> Thanks,
> Mark
- RE: Windows EPICS problem - PROBLEM SOLVED Mark Rivers
- Windows EPICS problem Mark Rivers
Re: cavget of a waveform Bob Soliday
<2008>
2025
2026
RE: Windows EPICS problem Jeff Hill
<2008>
2025
2026
