1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Archiver compiling problem with Xerces XML Library
To: [email protected]
Cc: [email protected]
Date: Mon, 14 Apr 2008 16:46:30 -0400
On Apr 13, 2008, at 05:25 , Tasaddaq Ali Khan wrote:
Dears
I have successfully compiled XML-RPC, Expat, XML Simple and Frontier by following the guideline given in the manul of Channel Archiver. But there are following errors when I tried to compile Xerces XML Library using make command. Can you guide me how to solve the problem?
invalid use of undefined type ‘struct xercesc_2_4::MemoryManager’
Newer compilers (like gcc 3.4.4 for RedHat WS 4, or gcc 4.0 as used on Mac OS 10.4)
need this patch:
Add
   #include <xercesc/framework/MemoryManager.hpp>
to
   src/xercesc/util/RefArrayOf.hpp
-Kay
Channel Archiver compiling problem with Xerces XML Library Tasaddaq Ali Khan
Prev: Re: TVME200 and IP-Octal 232 Martin L. Smith
Next: edm font file Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Channel Archiver compiling problem with Xerces XML Library Tasaddaq Ali Khan
Next: can't build R3.13 extension William F. Steele
