1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm font file
To: epics <[email protected]>
Date: Tue, 15 Apr 2008 15:09:55 -0700
Apparently the issue is related to whether I run edm remotely or
locally.
This is the error I get when using ssh
epics@cr0opi1 $ edm
Action file is
[/home/clsfs/epics/prod/cr0opi1/epics-extensions-3.14.9/src/edm//edmActions]
Using local access only
Font init failed - abort
This is the WARNING I get when running edm on the local machine
Note that in this case, edm starts
~/prod/cr0opi1/epics-lyncean/usr/src/drv/zt4612/edm
epics@cr0opi1 $ edm
Action file is
Action file is
xtErrorHandler - Cannot convert string
"-adobe-helvetica-medium-r-normal--0-[+0.0+12.0~12.0
+0.0]-75-75-p-0-iso8859-1" to type FontStruct
E
On Tue, 2008-04-15 at 10:05 -0700, Emmanuel Mayssat wrote:
> All,
> I am relatively new to edm.
> when I start it on one of my machine, I get the following error:
> I remember starting in the past edm on that machine.
> But I probably played with the fonts.list file since then.
> How do I generate that file in the first place?
> xlsfonts -fn "*-*-*-*-*-*" ?
> (xls font server is running on fedora core 4)
> I have EDMFONTFILE pointing to the fonts.list file I want to use.
> EDMFILE is set to the file's directory. Whatever I do with the
> environment, it complains about the Font.
> Any idea where the error could be coming from?
> Regards,
> E
Re: edm font file J. Lewis Muir
edm font file Emmanuel Mayssat
Prev: RE: multiple levels of substitution in msi Allison, Stephanie
Next: Re: edm font file J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: edm font file Emmanuel Mayssat
