1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm font file
To: [email protected]
Date: Tue, 15 Apr 2008 18:31:32 -0400
On 4/15/08 6:09 PM, Emmanuel Mayssat wrote:
> Apparently the issue is related to whether I run edm remotely or
> locally.
Hi, Emmanuel.
I don't have specific knowledge about EDM, but:
* Have you installed the fonts such that they are available to the X11
  server being used to display your EDM application?
* What command(s) are you using to log into the computer remotely and
  set up your X11 environment?  Are you using the ssh that comes with
  OpenSSH, and are you using it with the "-X" option?  Have you tried
  using the "-Y" option instead?
Lewis
Re: edm font file Emmanuel Mayssat
Prev: Re: edm font file Emmanuel Mayssat
Next: Re: edm font file Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
