1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm font file
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Tue, 15 Apr 2008 17:28:25 -0700
1/ X forward is set correctly with ssh
2/ I made an error when reporting the local error.
I found that the local error is due to the edm file I am opening.
The edl file I was looking at has been developed at another site.
There is some information about this in the documentation, but I cannot
really make sense of it.
How are fonts expended/matched?
How is fonts.list populated?
(I always used the one that came with the edm tar archive.)
When I start edm (without any edl file) locally it works.
When I do this through ssh, it reports a font error.
Font init failed - abort
Update:
If I ssh from a machine that has the same OS (fedora core 4), the error
disappear!!! When I ssh from a RH8.0 machine, edm report the Font init
failed - abort error.
Huh?!?!?
On Tue, 2008-04-15 at 18:31 -0400, J. Lewis Muir wrote:
> On 4/15/08 6:09 PM, Emmanuel Mayssat wrote:
> > Apparently the issue is related to whether I run edm remotely or
> > locally.
> Hi, Emmanuel.
> I don't have specific knowledge about EDM, but:
> * Have you installed the fonts such that they are available to the X11
>   server being used to display your EDM application?
> * What command(s) are you using to log into the computer remotely and
>   set up your X11 environment?  Are you using the ssh that comes with
>   OpenSSH, and are you using it with the "-X" option?  Have you tried
>   using the "-Y" option instead?
> Lewis
Re: edm font file Emmanuel Mayssat
Re: edm font file J. Lewis Muir
Prev: Re: edm font file J. Lewis Muir
Next: Re: edm font file Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
