1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: edm font init failed solution
To: [email protected]
Date: Wed, 16 Apr 2008 20:09:44 +0000 (GMT)
We just got done fighting with this and finally tracked down the problem edm was having to some problematic symlinks in /etc/X11/fontpath.d for the standard 75dpi,
100dpi, and misc xorg font packages.
https://bugzilla.redhat.com/show_bug.cgi?id=390171
According to bugzilla it's been fixed for months, but
no f8 update has been released, just devel/f9.
We were unable to implement the fix either through installing
the new packages (couldn't actually get them to install),
or by correcting the symlinks as extracted from the .rpm
using rpm2cpio and cpio; there must be more than just
changes to the symlinks themselves.
We added to the bug... we'll see what we hear back.  In the mean time the following command executed on the fc8 machine that you're trying to display on will fix the problem.
xset fp+ /usr/share/X11/fonts/75dpi
Now could someone tell us how to get edm to compile on fc8? We're having trouble because it wants to link with libXt.a, and we're not finding that in the fc8 rpms.
John Skinner and Matt Cowan
BNL/NSLS
Re: edm font init failed solution Emmanuel Mayssat
Prev: RE: multiple levels of substitution in msi Allison, Stephanie
Next: Re: edm font init failed solution Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Channel Archiver Build Problem Tasaddaq Ali Khan
