1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: multiple levels of substitution in msi
To: <[email protected]>, <[email protected]>
Date: Wed, 16 Apr 2008 08:48:27 -0700
Hi Benjamin,
Your change to convertRelease.pl plus the following 2 changes to base/configure/RULES.Db would be ideal:
# dbExpand
INSTALL_DBDFLAGS += -I $(INSTALL_LOCATION)/dbd
############# Add INSTALL_DBFLAGS for databases in the installation area
INSTALL_DBFLAGS  += -I $(INSTALL_LOCATION)/db
DBDFLAGS = $(USR_DBDFLAGS) -I . -I .. $(INSTALL_DBDFLAGS) $(RELEASE_DBDFLAGS)
############# Add INSTALL_DBFLAGS and RELEASE_DBFLAGS to the list of places that msi looks to find databases
DBFLAGS  = $($*_DBFLAGS) $(USR_DBFLAGS) -I. $(GENERIC_SRC_INCLUDES) $(INSTALL_DBFLAGS) $(RELEASE_DBFLAGS)
Thanks for the follow up on this issue.
Stephanie
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Benjamin Franksen
> Sent: Wednesday, April 16, 2008 1:24 AM
> To: [email protected]
> Subject: Re: multiple levels of substitution in msi
> To fix this, I propose to add this patch to the next base release:
> aragon: .../configure/tools > cvs diff -u -r epics_R3_14_9
> convertRelease.pl
> Index: convertRelease.pl
> RCS
> file:
> /opt/repositories/controls/epics/base/3.14/configure/tools/con
> vertRelease.pl,v
> retrieving revision 1.1.1.8
> retrieving revision 1.3
> diff -u -r1.1.1.8 -r1.3
> --- convertRelease.pl   1 Mar 2007 11:31:42 -0000       1.1.1.8
> +++ convertRelease.pl   7 Mar 2007 11:16:18 -0000       1.3
> @@ -220,6 +220,11 @@
>         next unless (-d "$path/dbd");
>         print OUT "RELEASE_DBDFLAGS += -I \$(strip \$($app))/dbd\n";
> +    foreach my $app (@includes) {
> +       my $path = $macros{$app};
> +       next unless (-d "$path/db");
> +       print OUT "RELEASE_DBFLAGS += -I\$(strip \$($app))/db\n";
>      close OUT;
> On Tuesday 15 April 2008 23:23, John Dobbins wrote:
> > Stephanie,
> > If I change
> > #13 Makefile to:
> >      TOP=../../..
> >      include $(TOP)/configure/CONFIG
> >      DB = second.db
> >      include $(TOP)/configure/RULES
> >      DBFLAGS += $(TOP)/db
> > but I can't seem to get DBFLAGS to appear automatically.
> > Is there a way to debug the RULES building part of the
> build process?
> > John
> > Allison, Stephanie wrote:
> > > Hi John,
> > > Your rule for inflating the database isn't properly using
> DBFLAGS so it
> > > doesn't have the directories with "db" in the include list.  Is it
> > > possible you are using a rule that is different from the one in
> > > base/configure/RULES.Db?
> > > Here is an example from my build (I have several modules
> included in my
> > > RELEASE which is why the long list of potential areas to
> find database
> > > files):
> > > Inflating database from ../evrEventAll.substitutions
> /nfs/slac/g/lcls/build/epics/extensions/extensions-R3-14-8-2/b
> in/linux-
> > >x86/msi -I. -I.. -I ../../../../db -I
> /nfs/slac/g/lcls/build/epics/modules/generalTime/generalTime-R1-2-1/db
> > > -I
> /nfs/slac/g/lcls/build/epics/modules/sSubRecord/sSubRecord-R1-0-1/db
> > > -I
> /nfs/slac/g/lcls/build/epics/modules/miscUtils/miscUtils-R1-0-1/db
> > > -I /nfs/slac/g/lcls/build/epics/base/base-R3-14-8-2-lcls2/db
> > > -I../O.Common -S../evrEventAll.substitutions  > msi.tmp
> > > mv msi.tmp ../O.Common/evrEventAll.db
> > > If you are using your own rule, you may need to add the
> "db" in front
> > > of the file name.  For example:
> > > file db/firstAll.db
> > >  	pattern { DEVICE  }
> > >  		  { device1 }
> > >  		  { device2 }
> > >  		   {device30}
> > > Stephanie
> > >> From: John Dobbins [mailto:[email protected]]
> > >> Sent: Tuesday, April 15, 2008 12:21 PM
> > >> To: Allison, Stephanie
> > >> Cc: EPICS Tech-Talk
> > >> Allison,
> > >> Using your suggestion (from January) I tried unsuccessfully
> > >> to get MSI to do
> > >> multiple levels of substitution. I am using 3.14.9 but I
> > >> assume that is not the
> > >> issue.
> > >> Setup:
> > >> #1  xxx
> > >> #2     Makefile
> > >> #3     configure/
> > >> #4     iocBoot/
> > >> #5     xxxApp/
> > >> #6        Makefile
> > >> #7        Db/
> > >> #8           first/
> > >> #9              Makefile
> > >> #10             firstAll.substitutions
> > >> #11             firstAll.template
> > >> #12          second/
> > >> #13             Makefile
> > >> #14             second.substitutions
> > >> #15       src/
> > >> Fails with:
> > >>     Inflating database from ../second.substitutions
> > >>     msi   -I. -I.. -I../O.Common
> -S../second.substitutions  > msi.tmp
> > >>     Could not open firstAll.db
> > >> firstAll.db  exists but not in any of the places MSI is
> > >> looking. How do I get
> > >> MSI to find it?
> > >> Details:
> > >> #6   Makefile is:
> > >>     TOP=../..
> > >>     DIRS += first
> > >>     DIRS += second
> > >>     include $(TOP)/configure/RULES_DIRS
> > >> #9  Makefile is:
> > >>     TOP=../../..
> > >>     DB = firstAll.db
> > >> #13 Makefile is:
> > >>     TOP=../../..
> > >>     DB = second.db
> > >> Thanks,
> > >> John Dobbins
> > >> Cornell University
> > >> Lab for Elementary Particle Physics
> > >>> Hi John,
> > >>>> Is there a way to get MSI to deal with multiple levels of
> > >>>> substitution?
> > >>> I divide my Db directory into sub-directories and build
> > >> them in the proper order.  For example:
> > >>> xxxApp/Db/first contains Makefile, first.db, and
> > >> firstAll.substitions:
> > >>> 	Makefile has:
> > >>> 		DB += firstAll.db
> > >>> 	firstAll.substitutions which looks something like this:
> > >>> 	file first.db
> > >>> 	pattern { DEV       , CARD , NAME    , ID
> > >> ,P0,P1,P2,P3,P4,P5,P6,P7,P8,P9,P10,P11,P12,P13,VME}
> > >>> 		  { $(DEVICE) ,   0  , NAME1   ,  1 , 0, 0, 0,
> > >> 0, 0, 0, 0, 0, 0, 0, 0 , 0 , 0 , 0 , 1 }
> > >>> 		  { $(DEVICE) ,   0  , NAME2   ,  2 , 1, 0, 0,
> > >>> 		  { $(DEVICE) ,   0  , NAME15  , 12 , 0, 0, 0,
> > >> 0, 0, 0, 0, 0, 0, 0, 0 , 0 , 0 , 1 , 1 }
> > >>> xxxApp/Db/second contains Makefile, second.substitutions:
> > >>> 	Makefile has:
> > >>> 		DB += second.db
> > >>> 	second.substitutions looks something like this:
> > >>> 	file firstAll.db
> > >>> 	pattern { DEVICE  }
> > >>> 		  { device1 }
> > >>> 		  { device2 }
> > >>> 		   {device30}
> > >>> and xxxApp/Db/Makefile looks like:
> > >>> 	TOP = ../..
> > >>> 	# first must be first since second will need for the
> > >> .db file created by first
> > >>> 	DIRS += first
> > >>> 	DIRS += second
> > >>> The RULES.Db files that come with epics 3.14.8.2 will do
> > >> the MSI properly - I don't think we had to change
> RULES.Db for this.
> > >>> If you don't like sub-directories, just create more *Db
> > >> directories under xxxApp:
> > >>> 	xxxApp/CommonDb1
> > >>> 	xxxApp/CommonDb2
> > >>> 	xxxApp/Db  (which depends on CommonDb1 and CommonDb2
> > >> being built first)
> > >>> 	xxxApp/Makefile must enforce proper build order
> > >>> Note there is a bug in the RULES somewhere that requires
> > >> the "{" that comes after the "file xxxx.db" to be on the next
> > >> line if xxxx.db comes from another module listed in your
> RELEASE file.
> > >>> 	Doesn't work:
> > >>> 	file xxxx.db {
> > >>> 	Works:
> > >>> 	file xxxx.db
> > >>> Hope this helps more than confuses...
> > >>> Stephanie Allison
> "Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
multiple levels of substitution in msi John Dobbins
RE: multiple levels of substitution in msi Allison, Stephanie
Re: multiple levels of substitution in msi John Dobbins
Re: multiple levels of substitution in msi Benjamin Franksen
Prev: Channel Archiver Build Problem Tasaddaq Ali Khan
Next: edm font init failed solution jskinner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: multiple levels of substitution in msi Benjamin Franksen
Next: Soft IOC VME access Robert Ellis
