1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm font init failed solution
To: [email protected]
Cc: [email protected]
Date: Wed, 16 Apr 2008 19:45:38 -0400
Hi John,
you need to get libXt-devel. That provides /usr/lib/libXt.so softlink to libXt.so.6.0.0
Matthieu
Emmanuel Mayssat wrote:
Adding:
Section "Files"
    FontPath        "/usr/share/X11/fonts/misc"
    FontPath        "/usr/share/X11/fonts/misc:unscaled"
    FontPath        "/usr/share/X11/fonts/100dpi"
    FontPath        "/usr/share/X11/fonts/100dpi/:unscaled"
EndSection
to /etc/X11/xorg.conf worked for me
We added to the bug... we'll see what we hear back.  In the mean time
the following command executed on the fc8 machine that you're trying
to display on will fix the problem.
xset fp+ /usr/share/X11/fonts/75dpi
No problem with 75dpi ...so far ;-)
Now could someone tell us how to get edm to compile on fc8? We're
having trouble because it wants to link with libXt.a, and we're not
finding that in the fc8 rpms.
[root@clark ~]# yum info libXt Loading "priorities" plugin Installed Packages Name : libXt Arch : i386 Version: 1.0.4 Release: 3.fc8 Size : 351 k Repo : installed Summary: X.Org X11 libXt runtime library Description: X.Org X11 libXt runtime library
[root@clark ~]# rpm -ql libXt
/usr/lib/libXt.so.6
/usr/lib/libXt.so.6.0.0
/usr/share/X11/app-defaults
/usr/share/doc/libXt-1.0.4
/usr/share/doc/libXt-1.0.4/AUTHORS
/usr/share/doc/libXt-1.0.4/COPYING
/usr/share/doc/libXt-1.0.4/ChangeLog
/usr/share/doc/libXt-1.0.4/NEWS
/usr/share/doc/libXt-1.0.4/README
I don't have it either :-(
fortunately I do not need edm on my f8 machine.
Good luck!
John Skinner and Matt Cowan
BNL/NSL
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
edm font init failed solution jskinner
Re: edm font init failed solution Emmanuel Mayssat
Prev: Re: edm font init failed solution Emmanuel Mayssat
Next: RE: autosave issues Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: edm runtime XtAddCallback errors John M. Skinner
