1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sub-array question
To: Tech-talk Talk <[email protected]>
Date: Thu, 24 Apr 2008 10:29:42 -0500
Every time I use a new version of EPICS base I make this change in the subArray code. Not the cleanest solution and I probably should have pushed harder to get the change in earlier since I encountered the same behavior in 2001.
Geoff
On Apr 24, 2008, at 10:11 AM, J. Lewis Muir wrote:
On 4/24/08 10:53 AM, John Dobbins wrote:
Dear All,
I have a waveform record which reads consecutive values from hardware
memory (happens to be Modbus over ethernet). I then use a subArray
record to pick out individual values. However if the hardware goes
off-line (so the waveform is temporarily invalid) the subArray record
changes its INDX field to 0! When the hardware comes back on-line the
subArray record now points to the wrong location in the waveform.
Is this intended? Suggestions for avoiding this situation?
Hi, John.
I reported the same problem last year. An archive of the discussion is at
http://www.aps.anl.gov/epics/tech-talk/2007/msg01432.php
I wish the fix could go into an earlier version of EPICS base, but maybe
Andrew is concerned about changing the behavior and thus possibly
breaking existing databases?
-lewis
J. Lewis Muir
Software Engineer
IMCA-CAT/CARS
sub-array question John Dobbins
Re: sub-array question J. Lewis Muir
Prev: RE: sub-array question Gillingham, IJ (Ian)
Next: RE: sub-array question Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
