Hi Jeff,
Wonderful! Please add this to R3.15 especially if you are under the hood making other CA changes.
Thank you VERY much,
Stephanie
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Monday, April 28, 2008 4:29 PM
> To: Allison, Stephanie; 'EPICS Tech-Talk'
> Subject: RE: Multiple IOCs on the same Host - question on
> dynamically allocated TCP Ports
> Hello Stephanie,
> The specific of how this gets configured would need to be
> worked out, but
> this does appear to be a good idea. If you would like I could add your
> request as a Mantis entry against R3.15 so I have a reminder
> to look at this
> sometime before R3.15 gets released?
> Jeff
> > From: [email protected]
> > On Behalf Of Allison, Stephanie
> > Sent: Monday, April 28, 2008 11:04 AM
> > To: EPICS Tech-Talk
> > Subject: Multiple IOCs on the same Host - question on dynamically
> allocated
> > TCP Ports
> > Hello,
> > When multiple IOCs run on the same host, using the same
> > EPICS_CA_SERVER_PORT, they use the same port for UDP
> channel connection
> > requests but have to use different ports for the CA TCP
> connection (of
> > course). The CA reference manual says:
> > "If the CA server library detects that a server is
> attempting to start on
> > the same port as an existing CA server then both servers
> will use the same
> > UDP port, and the 2nd server will be allocated an ephemeral
> TCP port."
> > Is there a way to set the allowable range of TCP ports that
> the IOC is
> > allowed to choose from for its TCP port? In particular, on
> a RHEL4 linux
> > server.
> > The reason for this is that we wish to have some of our CA clients,
> outside
> > our firewall, connect directly to IOCs (both RTEMS and
> linux) inside the
> > firewall. We don't want them to go through a CA proxy
> gateway process and
> > we don't want to have to set their EPICS_CA_ADDR_LISTs to include
> different
> > EPICS_CA_SERVER_PORT values. We also don't want to open up
> our firewall
> to
> > all TCP ports just to allow this communication but are
> willing to allow a
> > small range of predefined TCP ports. And we don't want to
> combine our
> IOCs
> > into one. Essentially, we want each soft IOC to use the same
> > EPICS_CA_SERVER_PORT for UDP connection requests but a
> predefined port for
> > the TCP connection (ie, a new environment variable like
> > EPICS_CA_SERVER_TCP_PORT which would be set differently in
> each of our
> soft
> > IOC startup files).
> > Any thoughts? Thank you,
> > Stephanie Allison
- Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Allison, Stephanie
- RE: Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Jeff Hill
Edm-1-11-1f compilation problem [SEC=UNCLASSIFIED] WANG, Jian
<2008>
2025
2026
RE: Multiple IOCs on the same Host - question on dynamically allocatedTCP Ports Thompson, David H.
<2008>
2025
2026
