1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Multiple IOCs on the same Host - question on dynamically allocatedTCP Ports
To: Jeff Hill <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 30 Apr 2008 10:06:51 -0400
 This has been on our wish list for some time too.  Just being able to
identify which soft IOC a PV, or a PV collision, is coming from would be
very useful.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Jeff Hill
Sent: Monday, April 28, 2008 7:29 PM
To: 'Allison, Stephanie'; 'EPICS Tech-Talk'
allocatedTCP Ports
Hello Stephanie,
The specific of how this gets configured would need to be worked out,
but
this does appear to be a good idea. If you would like I could add your
request as a Mantis entry against R3.15 so I have a reminder to look at
this
sometime before R3.15 gets released?
Jeff
> From: [email protected]
> On Behalf Of Allison, Stephanie
> Sent: Monday, April 28, 2008 11:04 AM
> To: EPICS Tech-Talk
> Subject: Multiple IOCs on the same Host - question on dynamically
allocated
> TCP Ports
> Hello,
> When multiple IOCs run on the same host, using the same
> EPICS_CA_SERVER_PORT, they use the same port for UDP channel
connection
> requests but have to use different ports for the CA TCP connection (of
> course).  The CA reference manual says:
> "If the CA server library detects that a server is attempting to start
on
> the same port as an existing CA server then both servers will use the
same
> UDP port, and the 2nd server will be allocated an ephemeral TCP port."
> Is there a way to set the allowable range of TCP ports that the IOC is
> allowed to choose from for its TCP port?  In particular, on a RHEL4
linux
> server.
> The reason for this is that we wish to have some of our CA clients,
outside
> our firewall, connect directly to IOCs (both RTEMS and linux) inside
the
> firewall.  We don't want them to go through a CA proxy gateway process
and
> we don't want to have to set their EPICS_CA_ADDR_LISTs to include
different
> EPICS_CA_SERVER_PORT values.  We also don't want to open up our
firewall
to
> all TCP ports just to allow this communication but are willing to
allow a
> small range of predefined TCP ports.  And we don't want to combine our
IOCs
> into one.  Essentially, we want each soft IOC to use the same
> EPICS_CA_SERVER_PORT for UDP connection requests but a predefined port
for
> the TCP connection (ie, a new environment variable like
> EPICS_CA_SERVER_TCP_PORT which would be set differently in each of our
soft
> IOC startup files).
> Any thoughts?  Thank you,
> Stephanie Allison
Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Allison, Stephanie
RE: Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Jeff Hill
Prev: RE: RTEMS-GeSys_2.1.beta and cexp-1.5 for uC5282 Coldfire Module K.M Ha
Next: RE: procServ V2.1.0 soft IOC server released Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Allison, Stephanie
Next: Edm-1-11-1f compilation problem [SEC=UNCLASSIFIED] WANG, Jian
