1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: procServ V2.1.0 soft IOC server released
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 30 Apr 2008 10:15:48 -0400
Wow!
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: Friday, April 25, 2008 11:55 AM
To: EPICS Tech Talk
Subject: procServ V2.1.0 soft IOC server released
Hello all,
procServ is an application originally written by Dave Thompson at SNS that creates an environment for running processes (such as soft IOCs) in the background while providing access to the console through a telnet port.
I recently added some options and fixed a few things - here's what it does now:
  • Can be used either standalone (it creates log files if told so), or under a central console access layer like conserver.
  • The auto-restart mode (can be toggled and configured) immediately restarts a soft IOC on exit or crash.
  • Has commands to manually shutdown and restart the soft IOC without losing the telnet connection.
  • Can be configured to write a daemon PID file to be used in standard system service scripts.
  • Console access is restricted to connections from localhost for security reasons, while you can configure a second, public, read-only port to allow other logging facilities to connect without going through an account.
For a more detailed description, see the documentation.
Download the application here.
Enjoy!
Cheers,
Ralph
procServ V2.1.0 soft IOC server released Ralph Lange
Prev: RE: Multiple IOCs on the same Host - question on dynamically allocatedTCP Ports Thompson, David H.
Next: Re: asyn/stream reconnect problems Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: procServ V2.1.0 soft IOC server released Ralph Lange
Next: Multiple IOCs on the same Host - question on dynamically allocated TCP Ports Allison, Stephanie
