1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Listing channels
To: <[email protected]>
Date: Wed, 07 May 2008 09:55:20 -0500
> 3. Is there a program that will extract a portion of an SDDS file?  In
> order to use SDDS for archiving (which it looks like it might be very
> useful for), [...]
Sorry, again not an answer to your question:
Why don't you want the channel archiver for archiving?
It's quite power full and meant to be used for archiving.
Cheers
Andreas
â----------------------------------
Actually, I use the channel archiver at the moment.  I'm probably going to continue using it, however from reading the SDDS documentation, I like the idea of being able to manage independent "...Self Describing..." data sets around.  Some of our compliance reporting targets could use that 'independence' so I'd be able to package up the official data for a report, generate the report from that data, and then be able to archive that data away.  Currently I'm having to use individual Access (ugh!) database files because of the amount of data I have to archive monthly.
Perhaps what would be better might be a method that would allow me to extract a SDDS dataset from a Channel Archive historical data set.
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Listing channels David Dudley
Prev: Re: Listing channels Bob Soliday
Next: Re: Listing channels Gasper Pajor
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
