1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Change input links run-time in a db
To: <[email protected]>
Date: Thu, 8 May 2008 14:31:57 +0100
Hello,
I'm trying to write a database where a waveform record (DTYP soft) can
have it's INP field changed at run-time to switch between one of two
other waveform records.
Basically I need a sort of multiplexing functionality to let one
waveform record collect the data from one of several other waveform
records. This can be done by changing the INP field of the resulting
waveform record to point to any one of the other waveforms.
When changing the waveform INP field with a dbpf command on the IOC
shell, things work Ok... When changing the INP field with a caput
(client side) in Linux shell, things work Ok...
However, I need to do the switching directly in the database. For this
purpose I am using an sCalcout record to create the string - using the
OUT field of the sCalcout to write to the waveform INP field... - This
doesn't work and I can't figure out why.
Does anyone know what could be the problem with my database (see below)
or have any suggestions how to program this kind of functionality in a
database? (not using genSub records or snl programs...)
record(waveform, wave1) {
  field(PINI, "YES")
  field(DTYP, "Soft Channel")
  field(NELM, "10")
  field(FTVL, "DOUBLE")
record(waveform, wave2) {
  field(PINI, "YES")
  field(NELM, "10")
record(scalcout, select) {
  field(CALC, "PRINTF('wave%d PP',A)")
  field(OOPT, "Every Time")
  field(OUT, "result.INP PP")
  field(DOPT, "Use CALC")
record(waveform, result) {
  field(NELM, "10")
Appriciate any help or suggestions. Thanks.
Ulrik
  Ulrik Pedersen               phone: +44(0)1235-778580
  Software Engineer            email: [email protected]
      Diamond Light Source Ltd.
      Rutherford Appleton Laboratory,
      Chilton, Didcot
      OxfordShire OX11 0DE
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
Re: Change input links run-time in a db Luedeke Andreas
Prev: Re: Listing channels Mark M. Ito
Next: Re: Change input links run-time in a db Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: unsubscribe :) Heinrich du Toit
