1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Change input links run-time in a db
To: "Pedersen, UK (Ulrik)" <[email protected]>
Cc: [email protected]
Date: Thu, 08 May 2008 16:35:35 +0200
Hi Ulrik,
the problem seems to arise from the fact, that the scalcout writes its VAL field instead of its SVAL field.
I get the error message on the console:
   Illegal Database Request Type PV: result.INP error detected in
   routine: dbPut - database request type is 0
This looks to me like a bug (sorry: undesired feature) of the scalcout record.
I found a strange workaround, maybe some EPICS guru can explains why it works:
   record(scalcout, select) {
     field(DTYP, "Soft Channel")
     field(INPA, "1")
     field(CALC, "PRINTF('wave%d PP',A)")
     field(OOPT, "Every Time")
     field(OUT,  "result.INP CA")
     field(DOPT, "Use CALC")
     field(FLNK, "result.PROC CA")
I just made the OUT link a channel access link and added an FLNK to process the modified waveform record, again an CA is required.
This works, but don't ask me why :)
Of course an INLINK can be as well a DOUBLE (constant) or a string (PV), it's up to the record to decide on what type of data to write.
But I found the same behaviour when first writing to an stringout records VAL field:
it only works if I use CA type OUTLINK _and_ FLNK.
Cheers Andreas
Pedersen, UK (Ulrik) wrote:
Hello,
I'm trying to write a database where a waveform record (DTYP soft) can
have it's INP field changed at run-time to switch between one of two
other waveform records.
Basically I need a sort of multiplexing functionality to let one
waveform record collect the data from one of several other waveform
records. This can be done by changing the INP field of the resulting
waveform record to point to any one of the other waveforms.
When changing the waveform INP field with a dbpf command on the IOC
shell, things work Ok... When changing the INP field with a caput
(client side) in Linux shell, things work Ok...
However, I need to do the switching directly in the database. For this
purpose I am using an sCalcout record to create the string - using the
OUT field of the sCalcout to write to the waveform INP field... - This
doesn't work and I can't figure out why.
Does anyone know what could be the problem with my database (see below)
or have any suggestions how to program this kind of functionality in a
database? (not using genSub records or snl programs...)
record(waveform, wave1) { field(PINI, "YES") field(DTYP, "Soft Channel") field(NELM, "10") field(FTVL, "DOUBLE") }
record(waveform, wave2) {
  field(PINI, "YES")
  field(NELM, "10")
  field(OUT, "result.INP PP")
record(waveform, result) {
  field(NELM, "10")
Appriciate any help or suggestions. Thanks.
Ulrik
  Ulrik Pedersen               phone: +44(0)1235-778580
  Software Engineer            email: [email protected]
      Diamond Light Source Ltd.
      Rutherford Appleton Laboratory,
      Chilton, Didcot
      OxfordShire OX11 0DE
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
</FONT></DIV>
RE: Change input links run-time in a db Pedersen, UK (Ulrik)
Prev: Change input links run-time in a db Pedersen, UK (Ulrik)
Next: RE: Change input links run-time in a db Pedersen, UK (Ulrik)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
