1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IP Card Problems on the Acromag Carrier 9670
To: Darrell Nineham <[email protected]>
Cc: [email protected]
Date: Fri, 09 May 2008 09:44:44 -0500
Hi Darrell,
Darrell Nineham wrote:
Auto Clearing the Interrupt considerably reduces the ISR Loading and
eases the IP Code, so I am surprised it is not the default for 9670 /
drivers.
The drvXy9660.c carrier driver that was added to drvIpac version 2.9 (which I believe can control the Acromag 9670 card) does set the CSR_ACE bit of the Control/Status register. My guess is that you were probably investigating Andy Foster's original carrier driver which I haven't looked at recently — can you confirm that?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: IP Card Problems on the Acromag Carrier 9670 Darrell Nineham
Prev: IP Card Problems on the Acromag Carrier 9670 Darrell Nineham
Next: RE: IP Card Problems on the Acromag Carrier 9670 Darrell Nineham
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
