1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: IP Card Problems on the Acromag Carrier 9670
To: <[email protected]>
Date: Fri, 9 May 2008 15:09:22 +0100
Dear Fellow Tech Talkers,
We have had some customers reporting problems with Hytec IP Cards when
used on the Acromag 9670, such a combination producing the continual
error....
Interrupt: uninitialized vme interrupt 255
Careful analysis here has discovered that the correct interrupt vector
is initially put out and serviced for one interrupt cycle, but then the
Acromag 9670 continues to generate interrupts even though there is no
interrupt source.  Since there is no interrupt source there is no
interrupt vector and the default 255 is read.
The default acromag 9670 setup leaves it without its Auto Clear
Interrupts Enabled, where as the Hytec 8002 default is to only generate
an interrupt whilst an interrupt source exists.  All the Hytec IP Cards
were written expecting this behaviour.
The Acromag Manual in its "Generic Interrupt Handler Actions" section
recommends a rather fiddly and lengthy way for the IP Cards ISR to clear
not only its own interrupt source but then also clear the 9670s.
There is a simpler fix, which is to enable the 9670's Auto Clear
Interrupt (i.e. set bit D7 in the Acromag 9670 Carrier Board Status
Register).
This fix should probably still work with other IP Cards, even if they
follow the alternative "Generic Interrupt Handler Actions" described on
page 11 of the Acromag manual is enacted, the carrier interrupt is
effectively disabled twice.
Auto Clearing the Interrupt considerably reduces the ISR Loading and
eases the IP Code, so I am surprised it is not the default for 9670 /
drivers.
I hope this information is of some help to anyone struggling with the
9670.
Regards
Darrell Nineham
Hytec Electronics Ltd.
Tel: +44 (0) 118 975 7770
Fax: +44 (0) 118 975 7566
Web: www.hytec-electronics.co.uk
Incorporated in England No 1246940
VAT NO GB 285 2479 27
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they are
addressed. If you have received this email in error, please notify the
sender immediately. The views expressed in the message are those of the
individual author and may not necessarily represent the views of Hytec
Electronics Ltd.
Re: IP Card Problems on the Acromag Carrier 9670 Andrew Johnson
Prev: RE: Change input links run-time in a db Pedersen, UK (Ulrik)
Next: Re: IP Card Problems on the Acromag Carrier 9670 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: New version of the sscan module Tim Mooney
