1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Missing include in WIN32/osdTime.cpp?
To: [email protected]
Date: Sun, 25 May 2008 07:50:34 +0800
Hi everybody,
I happened to know that there's a new CVS while I was trying to make
a cross-compiler toolchain on Windows, MinGW. But the compilation
failed because of some undeclared function called generalTimeCurrentTpRegister
on line 99 of osdTime.cpp. I took a little search and find that function
was defined in generalTimeSup.h. So I put
#include "generalTimeSup.h"
in the preamble and I can pass the error. Is there any possibility that
it is missed or could I do something clever to make it work without
modifying the source file, it really scared that I have to hack the sources.
By the way, after I've skipped the error mentioned above, I got something
else:
Installing created file ../../../bin/mingw-x86/makeBpt.exe
../../../bin/mingw-x86/makeBpt.exe ../bptTypeJdegC.data
../O.Common/bptTypeJdegC.dbd
../../../bin/mingw-x86/makeBpt.exe ../bptTypeJdegF.data
../O.Common/bptTypeJdegF.dbd
../../../bin/mingw-x86/makeBpt.exe ../bptTypeKdegC.data
../O.Common/bptTypeKdegC.dbd
../../../bin/mingw-x86/makeBpt.exe ../bptTypeKdegF.data
../O.Common/bptTypeKdegF.dbd
Installing created dbd file ../../../dbd/bptTypeJdegC.dbd
Installing created dbd file ../../../dbd/bptTypeJdegF.dbd
Installing created dbd file ../../../dbd/bptTypeKdegC.dbd
Installing created dbd file ../../../dbd/bptTypeKdegF.dbd
../../../bin/mingw-x86/dbToMenuH.exe ../menuConvert.dbd
../O.Common/menuConvert.h
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
make[3]: *** [../O.Common/menuConvert.h] Error 3
make[3]: Leaving directory `/home/Administrator/base/src/bpt/O.mingw-x86'
make[2]: *** [install.mingw-x86] Error 2
make[2]: Leaving directory `/home/Administrator/base/src/bpt'
make[1]: *** [bpt.install] Error 2
make[1]: Leaving directory `/home/Administrator/base/src'
make: *** [src.install] Error 2
I guess maybe it is the END-OF-LINE character problem but I don't know
how to solve it.
My environment is:
MSYS-1.0.10 with make 3.81
MinGW version GCC 4.3.0
GnuWin32 version readline library 5.0-1
Some other libraries as bison or flex which I don't know whether they
are necessary.
Best Regards
Chen
Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
| www.sinap.ac.cn
Re: Missing include in WIN32/osdTime.cpp? Andrew Johnson
Prev: Problems building with Microsoft Visual Studio 2005 (VC8) Mark Rivers
Next: create_channel fails on vxWorks Felix
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: [APS Beamline_controls] Problems building with Microsoft VisualStudio 2005 (VC8) Tim Graber
Next: Re: Missing include in WIN32/osdTime.cpp? Andrew Johnson
