Hi all, I setup an epics x86-ioc attached to a tcp server, the ioc listens to known size packets from the server and fills an epics waveform record with the data. The packets are ~21kB and update at ~50Hz, our clients have EPICS_CA_MAX_ARRAY_BYTES set. One of our user reported seeing intermittent corrupt values, the rate is highly unpredictable: one bad sample every few seconds to few minutes. I setup two minimal test clients to check what was happening - 1. one polling ca_get (which is how my user implemented his client app) 2. another using ca_monitor (1) reproduce the problem while (2) appears trouble free. I remember reading a post on tech-talk about string/array not being buffered and thought that might explain the issue with (1), something like concurrent read/write maybe. Could this be the issue? Also, I was wondering if (2) is guaranteed to be consistent? Do I need to put something else in place so every single waveform update will be consistent. Thanks, Matthieu -- Matthieu Bec Gemini Observatory Tel: +56 51 205785 c/o AURA, Casilla 603 Fax: +56 51 205650 La Serena, Chile
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
