1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: combining problem with etherip and motor
To: Zheng Lifang <[email protected]>
Cc: [email protected]
Date: Mon, 02 Jun 2008 12:16:16 -0500
Ron Sluiter wrote:
> I don't know the AB ControlLogix 5561, but you will have to make sure
> that it is not using A16 memory from 0xFBFF F000 -> 0xFBFF F100.
Correction; I should have said "you will have to make sure that it is
not using A16 memory from 0xF000 -> 0xFFFF.
>> Dear all,
>> For some reasons, I want to combine the source codes of AB
>> ControlLogix with the ones of motorR-6-2-2 in one VME/MVME5500.
>> The hardware environments are:
>> VME/MVME5500
>> MAXv-8000
>> The software environments are:
>> Tornado2.2/VxWorks5.5.1
>> EPICS base 3.14.8.2
>> ether_ip.tgz (from SNS:EtherIP link)
>> motorR6-2-2.tar.gz
>> I have tested with the following:
>> 1. If IOC runs ether_ip or motorR6-2-2 individually, everything works OK.
>> 2. After combining these two kinds of source codes together, there are
>> some strange things happened:
>> 1) Usually MAXv-8000 can be initialized normally, but there are some
>> problems with PLC. All PVs exists in IOC, but the displayed values on
>> EDM/OPI are zeros.
>> 2) Occasully I made a mistake: the address of MAXv-8000 is set to
>> 0xE000, but I use "MAXvSetup(1,16,0xF000,180,6,10) in st.cmd. So
>> MAXv-8000 can't be initialized, but this time the EPICS system of PLC
>> works OK.
>> I am not sure if there is something conflict with these two source
>> codes. Any suggestion and idea are welcomed.
>> Thanks&Best Regards,
>> Lifang
combining problem with etherip and motor Zheng Lifang
Re: combining problem with etherip and motor Ron Sluiter
Prev: Re: combining problem with etherip and motor Ron Sluiter
Next: MEDM's Shell Command + su Bertrand H.J. Biritz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Power Supply Info Ahed Aladwan
