The document to which Andrew referred: http://www.aps.anl.gov/epics/base/R3-14/8-docs/ConvertingR3.13AppsToR3.14.html describes how to convert an application or support module from the R3.13 build environment to the R3.14 build environment. If you have an EPICS support module that you want to get working on vxWorks with R3.14 then this is the document to use. The document to which I referred: http://www.aps.anl.gov/epics/wiki/index.php/How_to_make_your_EPICS_driver_operating_system_independent is a quick outline of the changes needed to convert a vxWorks driver to work with vxWorks or RTEMS (or uClinux, I suppose). You'll need to also make the changes noted in the document that Andrew mentioned to be able build in the EPICS R3.14 environment. -- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
