1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 80 MHz version of uCDIMM ColdFire 5282
To: "'Eric Norum'" <[email protected]>
Cc: [email protected]
Date: Tue, 10 Jun 2008 23:47:03 +0900
Hi Eric,
>>Do you have this value in the ColdFire environment?
>>_0=10000000:400000:RW
Default value is configured by Arcture company like this;
_0=10000000:100000:RW
And changed value to _0=10000000:400000:RW After rebooting the Coldfire and
tried to flash burning.
Yes, Now successfuly booting and worked!!!
Thank you for a  tough advice and help!!!!!
Now i can go ahead to my application.
B$ printenv
FACTORY=Arcturus Networks Inc.
REVISION=uC5282 Rev 1.1 16MB External Flash
SERIAL=X4747379F-01DB8
CONSOLE=ttyS0
KERNEL=0:linux.bin
KERNEL_ARGS=root=/dev/mtdblock0 quiet
HWADDR0=00:06:3B:00:AD:B8
FW_VERSION=010808004
RAMIMAGE=yes
CACHE=on
NETMASK=255.255.255.0
NAMESERVER=141.223.1.2
GATEWAY=141.223.48.99
HOSTNAME=Linac00:BI38
NTPSERVER=141.223.182.106
AUTOBOOT=3
IPADDR0=141.223.48.203
[email protected]:/home/hkm:/home
CMDLINE=/home/work/pad_base-3.14.8.2/st.cmd
INIT=141.223.48.202:/home/hkm:work/st.sys
B$
B$ go
Copy...done
go! 0x40000
Welcome to RTEMS GeSys
This system $Name: GeSys_2_4 $ was built on 20080609KST23:58:02
$Id: init.c,v 1.43 2008/03/22 20:36:13 guest Exp $ Installing TIOCGWINSZ
line discipline: ok.
To skip initialization, press a key now...
No ifcfg argument; using 1st interface after loopback...
Configuring 'fs1' from boot environment parameters...
fs1 141.223.48.203/255.255.255.0
gateway: 141.223.48.99
hostname: Linac00:BI38
fs1: Ethernet address: 00:06:3b:00:ad:b8 This is RTEMS-RPCIOD Release $Name:
R_rtems_nfs_1_7 $
($Id: rpcio.c,v 1.44 2008/04/29 15:49:05 strauman Exp $)
  # Use DMA timer 0 (DMA timer = 0x10, add timer #)
  #uC5282WatchdogType = 0x10
  # Start watchdog with priority 20
  #wdStart(20)
Type 'cexpsh.help()' for help (no quotes)
Cexp>
Kiman Ha,
registering IOC shell functions Matthew Pearson
uC5282 based RTEMS FlashSize error K.M Ha
80 MHz version of uCDIMM ColdFire 5282 Eric Norum
RE: 80 MHz version of uCDIMM ColdFire 5282 K.M Ha
Prev: Re: How to Upgrade Epics R3.13 device driver to Epics R3.14 Eric Norum
Next: registering IOC shell functions Matthew Pearson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: 80 MHz version of uCDIMM ColdFire 5282 K.M Ha
