I started uC5282 80 MHz testing from today.
So, i am just testing RAM based and Flash based booting.
After that i will try to bus interface with external chipset (e.g CPLD).
Changed flag options from your comment;
ARCH_DEP_LDFLAGS += -Wl,'--defsym' -Wl,'_FlashSize=16M'
Compiles were OK,
But, flash booting was fault with below error messages;
B$ tftp
uCTFTP Console 1.0 is running ...
done
B$ program
erase... done
write... done
B$ go
Copy...access fault
PC[0x48082700] SSP[0x0001fe48] BootstrapSP[0x0001fff0]
D0 D1 D2 D3 D4 D5 D6 D7
0x0003ffff 0x0003fffe 0x00040000 0x00000000 0x0000d50a 0x00000001 0x0001ff44
0x00000000
A0 A1 A2 A3 A4 A5 A6
0x00020000 0x01000001 0x0001ff44 0x0000b1c6 0x0001ff44 0x00012310 0x0001ffa4
RAM booting is worked.
B$ goram
Go from RAM!
Go from 0x40000
Welcome to RTEMS GeSys
This system $Name: GeSys_2_4 $ was built on 20080609KST23:58:02
$Id: init.c,v 1.43 2008/03/22 20:36:13 guest Exp $
Installing TIOCGWINSZ line discipline: ok.
To skip initialization, press a key now...
No ifcfg argument; using 1st interface after loopback...
Configuring 'fs1' from boot environment parameters...
fs1 141.223.48.203/255.255.255.0
gateway: 141.223.48.99
hostname: Linac00:BI38
fs1: Ethernet address: 00:06:3b:00:ad:b8
This is RTEMS-RPCIOD Release $Name: R_rtems_nfs_1_7 $
($Id: rpcio.c,v 1.44 2008/04/29 15:49:05 strauman Exp $)
Till Straumann, Stanford/SLAC/SSRL 2002
See LICENSE file for licensing info
This is RTEMS-NFS Release $Name: R_rtems_nfs_1_7 $
($Id: nfs.c,v 1.49 2008/04/24 21:45:04 guest Exp $)
Do you have a any ideas for solve flash booting?
Kiman,
-----Original Message-----
Sent: Monday, June 09, 2008 11:39 PM
To: K.M Ha
Cc: [email protected]
Subject: 80 MHz version of uCDIMM ColdFire 5282
I have a question to those using the 80 MHz version of the ColdFire uCDIMM
5282. How do you connect this to external logic such as an FPGA? Here's
the bus timing section of the data sheet:
- uC5282 based RTEMS FlashSize error K.M Ha
- 80 MHz version of uCDIMM ColdFire 5282 Eric Norum
How to Upgrade Epics R3.13 device driver to Epics R3.14 Szalata, Zenon M.
<2008>
2025
2026
RE: 80 MHz version of uCDIMM ColdFire 5282 K.M Ha
<2008>
2025
2026
