1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Longout Record ?
To: [email protected]
Date: Thu, 12 Jun 2008 10:56:50 -0500
On Wednesday 11 June 2008 17:25:35 Szalata, Zenon M. wrote:
> I have observed the following undesirable behavior in a combination of
> longout record and a EDM Text Control widget set to display format "Hex":
> When I enter the value 0x80000000 in the text control, it gets converted in
> the record to 0x7fffffff.  I suppose that either the EDM widget or the
> epics longout record perform signed conversion.  But why 0x7fffffff?  I
> have tested this on a pure software IOC running on Linux.  Now, when I
> enter 0x80000000 I want that to be the value in the record.  Is it possible
> that longout is not appropriate for this?  If so, what record type should I
> use?
Assuming you're using the target architecture linux-x86 and not linux-x86_64
(which is known to not work properly), your longout.VAL field is a signed
32-bit integer, which can hold values from -2147483648 to 2147483647 decimal.
In hex, those values are -0x80000000 through 0x7fffffff but note the sign on
the one - it's negative.  It is not possible to express the value +2147483648
as a signed 32-bit integer, although as an unsigned number its hex
representation is 0x80000000.  Note that CA doesn't support unsigned types;
there is no DBF_ULONG available to CA clients, although the IOC side does
implement this type, which CA transports using a DBF_DOUBLE.
Can you enter the value -0x80000000 properly into your EDM Text Control?
I'm not sure precisely where your value is being clipped, but I would suspect
EDM since the IOC doesn't do numeric conversions of hex numbers sent over CA
as a DBF_STRING.
HTH,
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Longout Record ? Szalata, Zenon M.
Prev: Longout Record ? Szalata, Zenon M.
Next: Re: camonitor prints CA errors to stdout rather than stderr J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Another question about mbboDirect record Carl Lionberger
