Hello Jerome,
The message means that the OMS VME58 driver has not detected any
change in the position feedback after 10 polling samples while the motor
was supposed to be moving.
You either have a problem with your position feedback device or the
motor is being moved very slowly with a high polling rate (i.e. the last
argument in "oms58Setup").
Hope this helps,
Ron
[email protected] wrote:
Hello all,
I have some troubles with command HOMR on driver OMS58-4S with servo
amplifier
and with a resolver feedback go to oms board.
i have a error message wich indicate a strange timeout whiche come
from epics driver v6.22
A message is :
"Sevr = minor Motor motion timeout ERROR on card 0, signal 2"
thanks you per advance
JEROME HOSSELET
- -- OMS58 PROBLEM Sevr = minor Motor motion timeout ERROR on card 0, signal 2 -- Jerome . Hosselet
edm 1-11-1g segfault in FC9 Kevin Anderson
<2008>
2025
2026
<2008>
2025
2026
