1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: edm 1-11-1g segfault in FC9
To: [email protected]
Date: Thu, 19 Jun 2008 17:40:19 -0400
Greetings,
It took some minor persuasion, but I managed to get edm 1-11-1g (the latest version) to compile under Fedora Core 9. Unfortunately, the application is largely unstable. In particular, it crashes with a "Segmentation Fault" whenever I attempt to place a Menu Mux object. It also crashes rather frequently (but unpredictably) when I'm accessing the Help files (particularly when I close the files after viewing them).
The Menu Mux object does appear in the window the instant before edm crashes. In addition, if I open an EDL file that contains a Menu Mux object, edm only crashes when I try to access the properties for the object.
I installed openmotif-2.3.0-0.3.fc8.ccrma.i386.rpm and openmotif-devel-2.3.0-0.3.fc8.ccrma.i386.rpm initially, but have since tried openmotif-2.2.3-2.i386 and openmotif-devel-2.2.3-2.i386 with the same result. There's an older message on the list that suggests removing the devel packages, but the header files they contain appear to be necessary.
Any suggestions as to what the problem might be?
Regards, Kevin.
Prev: Re: -- OMS58 PROBLEM Sevr = minor Motor motion timeout ERROR on card 0, signal 2 -- Ron Sluiter
Next: RE: unhandled exception in timerQueue Matthew Pearson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: edm 1-11-1g segfault in FC9 Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
