Sorry for the delay in responding, first beam got in the way...
I noticed that there are two more pending timerQueue tasks, which might
explain why everything still works.
The stack trace for the suspended process is:
231ff8 vxTaskEntry +68 : 1ea3ad00 ()
1ea3ad70 epicsThreadPrivateGet+f8 : 1ea2c94c ()
1ea2c94c epicsThreadCallEntryPoint+444: __cp_exception_info ()
162680 __cp_exception_info+0 : __default_unexpected(void) ()
16263c set_terminate(void (*)(void))+0 : terminate(void) ()
16262c __default_unexpected(void)+0 : cplusTerminate(void) ()
153c50 cplusTerminate(void)+50 : taskSuspend ()
The error code listed in the task list, means S_objLib_OBJ_UNAVAILABLE
the task information is:
NAME ENTRY TID PRI STATUS PC SP ERRNO
DELAY
timerQueue 1ea3ad00 1e0ab530 148 SUSPEND 22bbf4 1e0ab090
3d0002 0
stack: base 0x1e0ab530 end 0x1e0a8650 size 11712 high 3184 margin
8528
options: 0xc
VX_DEALLOC_STACK VX_FP_TASK
VxWorks Events
Events Pended on : Not Pended
Received Events : 0x0
Options : N/A
r0 = 6acfc1 sp = 1e0ab090 r2 = 0 r3 =
0
r4 = 1e0ab0a0 r5 = 1e0aafa0 r6 = 1e0ab030 r7 =
1e0aaf90
r8 = 1e0ab020 r9 = 2bfc8f3b r10 = 1ea725f0 r11 =
43300000
r12 = 1eb27ed0 r13 = 0 r14 = 0 r15 =
0
r16 = 0 r17 = 0 r18 = 0 r19 =
0
r20 = 0 r21 = 0 r22 = 0 r23 =
0
r24 = 0 r25 = 0 r26 = 1ea7a5b8 r27 =
1ea330dc
r28 = 1ea48068 r29 = 1ea324ac r30 = 1e0ab530 r31 =
1e0ab530
msr = b030 lr = 1ea484ec ctr = 19ac34 pc =
22bbf4
cr = 20000049 xer = 0
fpcsr = b2002100
fr0 = 0 fr1 = 0 fr2 = NaN fr3 =
NaN
fr4 = NaN fr5 = NaN fr6 = NaN fr7 =
0
fr8 = 0 fr9 = 0 fr10 = 0 fr11 =
0
fr12 = 0 fr13 = 4.5036e+15 fr14 = NaN fr15 =
NaN
fr16 = NaN fr17 = NaN fr18 = NaN fr19 =
NaN
fr20 = NaN fr21 = NaN fr22 = NaN fr23 =
NaN
fr24 = NaN fr25 = NaN fr26 = NaN fr27 =
NaN
fr28 = NaN fr29 = NaN fr30 = NaN fr31 =
NaN
On Tue, 2008-06-17 at 09:31 -0600, Jeff Hill wrote:
> Hello Mathew,
> My best guess (subject to change of course :-) is that some tangential code
> is corrupting the semaphore id used by a timer queue thread.
> > epicsThread: Unexpected C++ exception "epicsEvent::invalidSemaphore()"
> This is coming from the last chance exception handler in the epicsThread
> class. It is not a message from the dreaded unexpected exception handler in
> the CRTL (associated with violated exception specifications). I will fix the
> message emitted by epicsThread so that this is clear in the future.
> > > interrupt: Main interrupt with no cause
> This output might be supporting evidence for the corruption theory.
> Please try also the vxWorks shell "tt" command for the suspended thread.
> That may, or may not, provide some useful information.
> Jeff
> > -----Original Message-----
> > From: [email protected] [mailto:[email protected]]
> > On Behalf Of Matthew Pearson
> > Sent: Tuesday, June 17, 2008 6:52 AM
> > To: Andrew Johnson
> > Cc: [email protected]
> > Subject: Re: unhandled exception in timerQueue
> > Update:
> > I've just seen the same again (after a reboot, and a couple of hours)...
> > but the IOC shell is fine.
> > 0x1e0ab530 (timerQueue): Unhandled C++ exception resulted in call to
> > terminate
> > with type "Q210epicsEvent16invalidSemaphore" in thread "timerQueue" at
> > TUE JUN 17 2008 11:50:26.620275542
> > I also see:
> > 3d0002 0
> > Regards,
> > Matthew
> > On Tue, 2008-06-17 at 13:46 +0100, Matthew Pearson wrote:
> > > Hi Andrew / Tech-Talk,
> > > I've just seen the following printout in my vxWorks IOC shell (EPICS
> > > 3.14.8.2):
> > > 0x1e0abd20 (timerQueue): Unhandled C++ exception resulted in call to
> > > terminate
> > > FRI JUN 13 2008 16:51:01.488894248
> > > 0x1e03e550 (timerQueue): Unhandled C++ exception resulted in call to
> > > terminate
> > > FRI JUN 13 2008 16:56:38.279153464
> > > It looks like an Q210epicsEvent16invalidSemaphore exception is thrown
> > > from an epicsThread. But this seems to be unexpected, and unexpected()
> > > is called, which seems to exit the IOC shell.
> > > Nick Rees suspects that this was discussed a while ago, and may have
> > > been dealt with in a later version than 3.14.8.2. Any ideas?
> > > Regards,
> > > Matthew Pearson
> > > DLS Controls
> > <DIV><FONT size="1" color="gray">This e-mail and any attachments may
> > contain confidential, copyright and or privileged material, and are for
> the
> > use of the intended addressee only. If you are not the intended addressee
> > or an authorised recipient of the addressee please notify us of receipt by
> > returning the e-mail and do not use, copy, retain, distribute or disclose
> > the information in or attached to the e-mail.
> > Any opinions expressed within this e-mail are those of the individual and
> > not necessarily of Diamond Light Source Ltd.
> > Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> > attachments are free from viruses and we cannot accept liability for any
> > damage which you may sustain as a result of software viruses which may be
> > transmitted in or with the message.
> > Diamond Light Source Limited (company no. 4375679). Registered in England
> > and Wales with its registered office at Diamond House, Harwell Science and
> > Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> > </FONT></DIV>
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
- RE: unhandled exception in timerQueue Jeff Hill
- Re: camonitor prints CA errors to stdout rather than stderr J. Lewis Muir
- Re: camonitor prints CA errors to stdout rather than stderr Andrew Johnson
- unhandled exception in timerQueue Matthew Pearson
- Re: unhandled exception in timerQueue Matthew Pearson
edm 1-11-1g segfault in FC9 Kevin Anderson
<2008>
2025
2026
<2008>
2025
2026
