1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Pulse Train Record
To: "David Dudley" <[email protected]>, <[email protected]>
Date: Thu, 26 Jun 2008 09:11:21 -0400
If you have the OS tick rate at 1 K Hz,
You could set the BO's HIGH field to something .001 - 1 millisecond
set the SCAN rate to .01 Hz
It is unclear what the jitter would be on the scan task - it should be under 100 usecs if you are on vxWorks or RTEMS.
Does jitter matter or just the pulse rate?
How wide of a pulse is required?
It would be interesting to hear your results.
Bob
-----Original Message-----
Sent: Wed 6/25/2008 9:54 PM
To: [email protected]
Subject: Pulse Train Record
Is it possible to use a bo for a pulse train output?  I have an
application where I need to pulse a chemical metering pump which
requires a pulse train to control it at between 0-100 pulses per second,
and was wondering if I could use a simple digital output bit to do it,
or if I need some device support as well.
David Dudley
City of Corpus Christi
Re: Pulse Train Record Kurt Goetze
Pulse Train Record David Dudley
Prev: Pulse Train Record David Dudley
Next: Re: Question with sscan Record! Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Pulse Train Record Kurt Goetze
