1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Pulse Train Record
To: "Dalesio, Leo" <[email protected]>
Cc: David Dudley <[email protected]>, [email protected]
Date: Thu, 26 Jun 2008 11:34:56 -0500
I have done something similar to what Bob suggests, in order to have
a BI record (set to I/O Intr) trigger something else after a delay. With
sysClkRateSet(2000) set in my st.cmd file, I was able to set delays
with a resolution of 1msec. Jitter was surprisingly good, a few % of a msec,
iirc. The setup was VxWorks / MVME5100, in a crate with lots of other stuff.
The binary input was an IP-Unidig input.
I experimented with higher clock rates but 2000 seemed to be the cutoff
for high resolution coupled with reasonable jitter, on my setup.
One thing I wanted to point out is that any old (in my case SNL) code using
vxWorks taskDelays will be affected by this. Obviously your delays will get
much shorter with a faster clock rate! I found this out the hard way. Another
reason taskDelay() calls should be converted to epicsThreadSleep().
Kurt Goetze
Dalesio, Leo wrote:
If you have the OS tick rate at 1 K Hz,
You could set the BO's HIGH field to something .001 - 1 millisecond
set the SCAN rate to .01 Hz
It is unclear what the jitter would be on the scan task - it should be under 100 usecs if you are on vxWorks or RTEMS.
Does jitter matter or just the pulse rate?
How wide of a pulse is required?
It would be interesting to hear your results.
Bob
-----Original Message-----
Sent: Wed 6/25/2008 9:54 PM
To: [email protected]
Subject: Pulse Train Record
Is it possible to use a bo for a pulse train output? I have an
application where I need to pulse a chemical metering pump which
requires a pulse train to control it at between 0-100 pulses per second,
and was wondering if I could use a simple digital output bit to do it,
or if I need some device support as well.
David Dudley
City of Corpus Christi
Pulse Train Record David Dudley
RE: Pulse Train Record Dalesio, Leo
Prev: Re: Question with sscan Record! Tim Mooney
Next: New version of the sscan module Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Pulse Train Record Dalesio, Leo
Next: EPICS driver for iseg HV V . I . Stoica
