Subject: |
Re: Is it possible to give parameters to the Startup script (st.cmd) |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 30 Jun 2008 10:45:01 -0500 |
On Monday 30 June 2008 09:56:43 haquin wrote:
> I wonder if it is possible to give some parameters to the startup script ?
> Here is an exemple of what I'd like to do :
> >myioccore myst.cmd <parameter1> ... <parameterN>
There are a couple of ways to pass parameters into the IOC (on architectures
other than on vxWorks and RTEMS). If you don't want to write any code, you
can use environment variables as Eric suggested, which are made available
inside your st.cmd script using the ${NAME} or $(NAME) syntax. Of course
these won't look like the above example, you'd have to use something like
bash$ export NAME=value
bash$ myioc st.cmd
You could also write a wrapper script that takes arguments and sets them into
environment variables.
However since you have the source code to myioc in myiocApp/src/myiocMain.c
you can arrange to parse the command line arguments yourself and convert the
arguments into environment variables. You could look for positional
parameters, setting say the variables $(ARG1), $(ARG2) etc, or you could use
a named parameter syntax like NAME=VALUE, or best of all do both.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Is it possible to give parameters to the Startup script (st.cmd) haquin
Re: Is it possible to give parameters to the Startup script (st.cmd) Eric Norum
edm on later linux distros John Sinclair
<2008>
2025
2026
<2008>
2025
2026
