1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to use the output array of a waveform record ?
To: "Steven M. Hartman" <[email protected]>
Cc: [email protected]
Date: Wed, 09 Jul 2008 08:33:18 +0200
Steven M. Hartman a écrit :
You will need to use a subArray record to pull out the individual elements of your waveform to use in your subroutine record. Alternately, you can use a genSub record rather then a sub record and access the elements from within the routine.
Steve,
Does this mean that I have to use one subArray record for each individual element of my waveform ?
if not, my question remains ...
How to specify that the :
- INPA of the sub record is linked to the first element of the subArray array
- INPB of the sub record is linked to the second element of the subArray array
- INPK of the sub record is linked to the 11th element of the subArray array
I understand If I use a genSub record, I will be able to access the elements from within the routine,
but is it possible to output them to other records ?
Thanks fot your help
How to use the output array of a waveform record ? haquin
Re: How to use the output array of a waveform record ? Steven M. Hartman
Prev: Re: Ethernet-to-RS232 Mauro Giacchini
Next: RE: Ethernet-to-RS232 Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to use the output array of a waveform record ? Steven M. Hartman
Next: EPICS meeting in Padua Dalesio, Leo
